Re: new guy in the deep end January 15, 2015 01:28PM |
psneddon
More great info! Many thanks.
Yes, I'm using Marlin firmware. I was looking it over and seems to be one of the standard firmwares for 3d printing. I was able to test out my Ramps 1.4 and stepper motors and have managed to get Pronterface working the motors without having anything else hooked up - still dabbling and piecing it all together.
//// Temperature sensor settings: // -2 is thermocouple with MAX6675 (only for sensor 0) // -1 is thermocouple with AD595 // 0 is not used // 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) // 3 is Mendel-parts thermistor (4.7k pullup) // 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! // 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) // 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) // 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup) // 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) // 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup) // 10 is 100k RS thermistor 198-961 (4.7k pullup) // 11 is 100k beta 3950 1% thermistor (4.7k pullup) // 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed) // 13 is 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE" // 20 is the PT100 circuit found in the Ultimainboard V2.x // 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950
psneddon
I also purchased a RepRap Full Graphic LCD 12864 display but it's not working properly. I found that a lot of people were having problems with this display on their I3's - unfortunately, I didn't know that until after I bought it.
I was finally able to get the display to come on properly and I was able to access the first submenu, but the scroll knob doesn't work. So, I've put that aside for now and am waiting on my rods to arrive so I can get down to business building my I3 Rework.
psneddon
Unfortunately, the ones I find are all Bowden versions and I think I need to get a Wade style. I know it's probably one of the better hot ends out there right now, but were there any major problems using a standard J head with your printer?
psneddon
I expect a huge learning curve getting the printer to print properly and I also want to start with 1.75mm and work up to 3mm maybe later.
psneddon
So, a .4mm hole for the extruder head would be a good selection then?
Thanks again for the feedback and information!
Re: new guy in the deep end January 16, 2015 08:19AM |
Re: new guy in the deep end January 16, 2015 06:49PM |
Re: new guy in the deep end January 18, 2015 01:58PM |
psneddon
Yes, I was looking for a hot end that had one of the listed thermistors - still researching.
I put the u8glib library in two places and compiled it with no problems - the configuration.h tab and the first tab that opens up (can't remember the name right now).
The E3D hot end you refer to - isn't that a Bowden hot-end? Can I put a Bowden on a Wade extruder?
psneddon
I didn't know that 3mm was recommended for this 3d printer - I thought it could use 1.75mm and 3mm?
psneddon
I plan on doing most of the mechanical build prior to the hot end portions. That way I can be building and reading/learning as I go.
Re: new guy in the deep end January 18, 2015 05:46PM |
Re: new guy in the deep end January 18, 2015 07:59PM |
psneddon
I read the article on J-head clones and I think it really helped knowing the differences. It looked like most of the clones use an aluminum block head while the original ones use a brass head. Also, the information on the venting was very informative. So, I waded (no pun intended) through the ones on eBay and found this one:
[www.ebay.com]
It has a .35mm head for 3mm filament.
Also, there's this one:
[www.ebay.com]
Also has a .35mm head only for 1.75mm filament.
Both are listed as MK V-BV and use a "standard" Marlin compatible thermistor - 104GT-2 (option #5 in the configuration file).I don't know if it comes with the liner or not - I'd have to ask.
They both have the same specs, look identical and seem to use the same parts, yet one is for 3mm filament while the other is for 1.75mm filament. ???? What am I missing here???
It looks like you'd have to put them together yourself and there's no wiring included with either of them. That's probably why most people are going with the cheap ones - less work and less money.
Re: new guy in the deep end January 18, 2015 08:33PM |
aparkin
power supply
what's the recommended power supply for repraps i don't want something to cheep that i have to stand over it with a fire extinguisher and yet again i don't want a all singing and dancing power supply when all i need is for it to do its job reliably
Re: new guy in the deep end January 18, 2015 09:12PM |
Re: new guy in the deep end January 19, 2015 08:04AM |
Re: new guy in the deep end January 19, 2015 09:15AM |
Re: new guy in the deep end January 27, 2015 05:13PM |
Re: new guy in the deep end February 04, 2015 10:47AM |
aparkin
ok every thing is in the post now excpet thermistor for hot bed can any1 link me a 100k thermistor - best choice for EPCOS 100k (4.7k pullup) (ebay if possible i I'm ever over thinking it are just trying to do it way to tired
the other thing is on the ramps 1.4 i read people use only 2 wires from the end stop to the ramps board but what 2 wires i think its negative and signal and positive is left off is this correct
many thanks for putting up with my stupid questions
Re: new guy in the deep end February 04, 2015 11:33AM |
aparkin
Re: new guy in the deep end February 05, 2015 10:23AM |
Re: new guy in the deep end February 06, 2015 02:09PM |
Re: new guy in the deep end February 07, 2015 09:51AM |
Re: new guy in the deep end February 07, 2015 12:54PM |
Re: new guy in the deep end February 07, 2015 01:08PM |
