X & Y Axis - Use belts or use threaded rod??? August 14, 2010 05:38AM |
Re: X & Y Axis - Use belts or use threaded rod??? August 14, 2010 10:12AM |
Re: X & Y Axis - Use belts or use threaded rod??? August 14, 2010 10:52AM |
I presume the by turning the threaded rod it is a finer adjustment than the belt drive system. Is this correct?
Is there any reason or disadvantages why the X & Y axis cannot use the method of turning the threaded rod (similar to the way the Z axis moves) to move the carriage?
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: X & Y Axis - Use belts or use threaded rod??? August 14, 2010 02:25PM |
Re: X & Y Axis - Use belts or use threaded rod??? August 14, 2010 06:41PM |
Re: X & Y Axis - Use belts or use threaded rod??? August 14, 2010 09:54PM |
