Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 04, 2018 12:59PM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 04, 2018 04:24PM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 12:06AM |
//============================================================================= //============================== Movement Settings ============================ //============================================================================= // @section motion /** * Default Settings * * These settings can be reset by M502 * * Note that if EEPROM is enabled, saved values will override these. */ /** * With this option each E stepper can have its own factors for the * following movement settings. If fewer factors are given than the * total number of extruders, the last value applies to the rest. */ //#define DISTINCT_E_FACTORS /** * Default Axis Steps Per Unit (steps/mm) * Override with M92 * X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]] */ #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 4000, 94.96 } /** * Default Max Feed Rate (mm/s) * Override with M203 * X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]] */ #define DEFAULT_MAX_FEEDRATE { 200, 200, 10, 25 } /** * Default Max Acceleration (change/s) change = mm/s * (Maximum start speed for accelerated moves) * Override with M201 * X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]] */ #define DEFAULT_MAX_ACCELERATION { 100, 100, 5, 100 } /** * Default Acceleration (change/s) change = mm/s * Override with M204 * * M204 P Acceleration * M204 R Retract Acceleration * M204 T Travel Acceleration */ #define DEFAULT_ACCELERATION 100 // X, Y, Z and E acceleration for printing moves #define DEFAULT_RETRACT_ACCELERATION 150 // E acceleration for retracts #define DEFAULT_TRAVEL_ACCELERATION 100 // X, Y, Z acceleration for travel (non printing) moves /** * Default Jerk (mm/s) * Override with M205 X Y Z E * * "Jerk" specifies the minimum speed change that requires acceleration. * When changing speed and direction, if the difference is less than the * value set here, it may happen instantaneously. */ #define DEFAULT_XJERK 12.0 #define DEFAULT_YJERK 12.0 #define DEFAULT_ZJERK 0.4 #define DEFAULT_EJERK 5.0
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 04:40AM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 05:28AM |
/** * Default Axis Steps Per Unit (steps/mm) * Override with M92 * X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]] */ #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 4000, 94.69 } /** * Default Max Feed Rate (mm/s) * Override with M203 * X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]] */ #define DEFAULT_MAX_FEEDRATE { 300, 300, 5, 25 } /** * Default Max Acceleration (change/s) change = mm/s * (Maximum start speed for accelerated moves) * Override with M201 * X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]] */ #define DEFAULT_MAX_ACCELERATION { 2000, 2000, 100, 10000 } /** * Default Acceleration (change/s) change = mm/s * Override with M204 * * M204 P Acceleration * M204 R Retract Acceleration * M204 T Travel Acceleration */ #define DEFAULT_ACCELERATION 2000 // X, Y, Z and E acceleration for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration for retracts #define DEFAULT_TRAVEL_ACCELERATION 2000 // X, Y, Z acceleration for travel (non printing) moves /** * Default Jerk (mm/s) * Override with M205 X Y Z E * * "Jerk" specifies the minimum speed change that requires acceleration. * When changing speed and direction, if the difference is less than the * value set here, it may happen instantaneously. */ #define DEFAULT_XJERK 17.0 #define DEFAULT_YJERK 17.0 #define DEFAULT_ZJERK 0.4 #define DEFAULT_EJERK 5.0
// X and Y axis travel speed (mm/m) between probes #define XY_PROBE_SPEED 8000
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 05:50AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 07:01AM |
# max default feedrate (28, 28, 0.22, cold extrusion prevented) x,y,z,e
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 11:12AM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 11:15AM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 11:23AM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 11:27AM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 11:52AM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 11:59AM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 12:31PM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 05, 2018 01:05PM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 07, 2018 09:35AM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 07, 2018 09:59AM |
Re: Stepper motor beeeeeping problem with marlin firmware pls help me......... August 07, 2018 12:59PM |
