I think this is a fairly generic question, but just in case it matters, I'm working with a TechZone Lasercut Mendel.
My question is where to set the limit switches. I think I'm OK on the X limit, since I set it at the left edge of the build area. On the Y limit, I set it outside the build area so that I can access the purge slot. Is there a guideline on exactly where to set this? And especially on the Z limit: Should I set it where the hot end just touches the build platform, and if not, what is a good calibration tool for this? I've set it using a piece of paper, adjusting it so that it just begins binding the paper where the limit switch stops travel, but this seems to be too close. The first layer I print is smeared out flat.
