Programing my micro
Posted by buket of water
Programing my micro
November 09, 2011 08:23PM
Hey all.
My name is Chris, I live in Mackay, I am a lazy miner
anyway i brought an assembled printer (due to lazy miner-ness)
my was to use the printing for lost wax casting and plugs for moulds
So i have no idea with elecrontics and i am wonder if someone would like to see if they can get repsnapper to connect to the printer?
Re: Programing my micro
November 10, 2011 08:59PM
Hi Chris,
I'm in Blackwater, which is a close 4-hour drive from you. If you ever want to drop around, I'd be happy to have a look at your electronics, see if we can puzzle it out. I'm no expert by any means, but willing to give you a hand.
November 11, 2011 02:41AM
Thank you very much for the offer Shibboleth. Your just "around the corner" for work haha
I've made a lot of progress now but i think i've fried the X axis motor or its not plugged in correctly
November 11, 2011 05:07AM
more likely that the pololu is dead, switch the motor with a working one and see what happens.
ps: we're all using pronterface and sfact instead of repsnapper these days smiling smiley
Wooden Mendel
Teacup Firmware
November 11, 2011 06:44AM
Yeah im thinking the same.
i changed it to another axis and it worked
Im on the pronterface wagon too
November 11, 2011 10:00PM
buket,
I have been following your other posts [forums.reprap.org] but haven't been able to contribute much, as I don't know exactly what electronics a Glider comes equipped with. The manufacturer's website [www.reprapcentral.com] is a bit obscure, because they talk about both RAMPS and GEN6 - I thought these were different systems. Could you post a photo to help us work out what you actually have?
RAMPS [reprap.org] is an add-on board that goes onto an Arduino Mega, while GEN6 [reprap.org] is an all-in-one board that has the the Atmel microprocessor on it. My experience (very limited!) is with RAMPS; I haven't seen a GEN6.
If your problem is that you have a blown stepper controller, I may be able to help you out. I have a couple of spare StepStick modules [reprap.org] that I could pass on at cost. (I needed some spares after I blew one on my first attempt at wiring up.) I believe StepSticks are pin-compatible with Pololus, but I haven't tried myself to be 100% sure.
I am in Brisbane, so postage to central Queensland would be negligible. Let me know if you would like one.
Edited 1 time(s). Last edit at 11/11/2011 10:02PM by julianh72.
Follow my Mendel Prusa build here: [julianh72.blogspot.com]
November 11, 2011 11:22PM
it is RAMPS either 1.3/1.4
i swaped around the stepper controllers. so it is them. ordered some more off ebay. hopefully they will here before i return from work.
now to work out why my stl files come out really tiny.
im using solidedge v18.
soo many hoops
November 11, 2011 11:28PM
> tiny.
you're probably exporting with units set to inches.
Reprap is a metric project, so everything expects millimeters.
You need to either scale them by 25.4, or tell your CAD program to export with millimeter units.
Wooden Mendel
Teacup Firmware
November 12, 2011 02:44AM
bloody solidedge.
found this burried in wikki, have to download Art of Illusion, STL translator plugin
File->Import->STL (got an error but ignored it)
Object->Convert to Triangle Mesh
Object->Edit Object (opens mesh editor)
Edit->Select All
[optional] Mesh->Transform, (used 0,0,0 90,0,0 25.4,25.4,25.4 to scale and rotate)
Mesh->Simplify Selection (used 0.05)
close mesh editor
File->Export->STL
ALL good now
