vase problème sad smiley
Posted by boolat
June 15, 2015 01:18PM
bonjour
aujourd'hui j'ai imprimer une vase avec quelque default ..
a votre avis le problème viens de ou ?
voici ma config :
print
Build time: 2 hours 21 minutes
Filament length: 5643.5 mm
Plastic weight: 16.97 g (0.04 lb)
config
extruder:
nozzle dia: .40mm
extrusion multiplier: 1
extrusion width: .40mm
ooze control:
retract distance: 2.0mm
extra restart distance: .0mm
retract vertical lift: .0mm
retract speed: 1800mm/min
coast at end: disabled
wipe nozzle: disabled
layer settings,
layer height: .2mm
top solid layers: 4
bottom solid layers: 4
outer shells: 3
outline direction: inside-in
first layer height: 200%
first layer width: 100%
first layer speed: 70%
start points: optimize start points for faster printing speed is checked
additions tab,
skirt settings,
skirt layers: 3
skirt offset: 4mm
skirt outlines: 2
no -rafts
infill tab.
pattern: rectilinear
infill percentage: 10%
outline overlap: 15%
infill extrusion width: 100%
minimum infill length: 5.00mm
print sparse infill every: 1 layer
include solid diaphragm every 2 layers
standard infill angles were used
tempssad smiley I am printing with abs)
extruder: 230c
bed: 110c
other tab,
printing speed: 1800.mm/min
outline underspeed:70%
solid infill underspeed: 80%
support structure underspeed: 40%
x/y rapid speeds :3600mm/min
z rapid speed: 2400mm/min
filament,
1.75mm dia
MERCI !
Re: vase problème sad smiley
June 15, 2015 01:24PM
Faut Slicer avec l'option spiral vase winking smiley (dans le cas de Slic3r)
[www.hotends.fr ]>>>[email protected] >>>GitHUB ([github.com])
My SketchFab >[sketchfab.com]
June 15, 2015 01:53PM
ahhhhh ceci
thumbs up
je test.......
June 15, 2015 03:53PM
avec l'option vase ça à complètement foiré !
