bonsoir,
j'ai trouver sur github les paramètres d'Emmanuel,mais pas moyen de téléverser le config.h!!
toujours ces erreurs
Arduino : 1.8.12 (Windows 10), Carte : "Melzi 1284p 16mhz"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kourourei\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kourourei\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\kourourei\Documents\Arduino\libraries -fqbn=sanguino:firmwares:atmega1284 -vid-pid=0403_6001 -ide-version=10812 -build-path C:\Users\KOUROU~1\AppData\Local\Temp\arduino_build_818565 -warnings=none -build-cache C:\Users\KOUROU~1\AppData\Local\Temp\arduino_cache_83165 -prefs=build.warn_data_percentage=75 -verbose C:\Users\kourourei\Desktop\Marlin-1.0.x\Marlin-1.0.x\Marlin-1.0.x\Marlin\Marlin.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kourourei\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kourourei\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\kourourei\Documents\Arduino\libraries -fqbn=sanguino:firmwares:atmega1284 -vid-pid=0403_6001 -ide-version=10812 -build-path C:\Users\KOUROU~1\AppData\Local\Temp\arduino_build_818565 -warnings=none -build-cache C:\Users\KOUROU~1\AppData\Local\Temp\arduino_cache_83165 -prefs=build.warn_data_percentage=75 -verbose C:\Users\kourourei\Desktop\Marlin-1.0.x\Marlin-1.0.x\Marlin-1.0.x\Marlin\Marlin.ino
Using board 'atmega1284' from platform in folder: C:\Program Files (x86)\Arduino\hardware\sanguino\firmwares
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\sanguino\firmwares
Warning: Board sanguino:firmwares:atmega1284 doesn't define a 'build.board' preference. Auto-set to: FIRMWARES_ATMEGA1284
Detecting libraries used...
recipe.preproc.macros est un schéma manquant
Erreur de compilation pour la carte Melzi 1284p 16mhz
a vous lire.
merci
