Souci avec Slic3r May 15, 2013 05:13AM |
Re: Souci avec Slic3r May 15, 2013 05:36AM |
Re: Souci avec Slic3r May 15, 2013 05:44AM |
11:39:49.065 : Warning: The input file contains a hole near edge 24.000000-25.000000 (not manifold). You might want to repair it and retry, or to check the resulting G-code before printing anyway. 11:39:49.134 : => Processing triangulated mesh 11:39:50.954 : The model has overlapping or self-intersecting facets. I tried to repair it, however you might want to check the results or repair the input file and retry. 11:39:50.962 : => Generating perimeters 11:40:08.482 : => Detecting solid surfaces 11:40:08.989 : => Preparing infill surfaces 11:40:09.161 : => Detect bridges 11:40:09.180 : => Generating horizontal shells 11:40:09.219 : => Combining infill 11:40:09.219 : => Infilling layers 11:40:11.789 : => Generating skirt 11:40:11.794 : => Exporting G-code to C:\Users\acer\AppData\Local\RepetierHostSolidoodle\composition.gcode 11:40:24.717 : Done. Process took 0 minutes and 35.583 seconds 11:40:24.717 : Filament required: 1498.5mm (3.4cm3)
Re: Souci avec Slic3r May 15, 2013 05:51AM |
Re: Souci avec Slic3r May 15, 2013 05:55AM |
Re: Souci avec Slic3r May 15, 2013 09:56AM |
Re: Souci avec Slic3r May 15, 2013 10:22AM |
Re: Souci avec Slic3r May 15, 2013 10:32AM |
Re: Souci avec Slic3r May 15, 2013 10:53AM |
