Impression multicolore avec une buse July 15, 2013 09:54AM |
Re: Impression multicolore avec une buse July 16, 2013 05:15AM |
Admin Registered: 13 years ago Posts: 2,569 |
Re: Impression multicolore avec une buse July 16, 2013 09:43AM |
Re: Impression multicolore avec une buse July 16, 2013 09:55AM |
Re: Impression multicolore avec une buse July 16, 2013 10:10AM |
Re: Impression multicolore avec une buse July 18, 2013 01:06PM |
However, if you want to do this with anything else than the above mentioned setup, do the following, 1) Measure the amount of filament that your machine takes in per E's in your g-code. Do some experiment like, making the machine push 1000E's, 500E's or 5000E's, and look at the mm's of filament that went in the exturder. Now you know how many mm goes in say, 1000E's 2) Generate g-code for the thing(note that you need a fill for this print, especially to support the stem.), open it and look at the Z number at the last lines and note this down. This is how high your object is going to be in mm's. 3) Do the following calculation (total height of object) / 47 x 6 = the width of each color for your object. 4) Now that you have the height for each color, you can determine at what height in your object they are going to start. Note down the starting heights of each color. 5) Next, you can look again at the Z numbers in your g-code. First, find the point where Z is the closest to the width of your first color. For example, if the width is 8.04mm, look for something like 8.02 or 8.06. Just find the closest one. 6) When you find the right Z number, look at the E number behind it. Note this down. 7) Repeat step 6 until the green color. Note down each E number behind the corresponding Z number. 8) Calculate the difference in E numbers for each color layer. 9) Finally, divide these differences in E numbers by the mm/E that you calculated in step 1. This will give you the length of filament for each color. 10) Cut the filaments in the correct size and preferably join them before printing by your favorite method of choice. If you haven't done this before, look around a bit for how people do it. Note: Actually, you don't want to cut the green, because if you do, you will have the risk of running out of filament for your print because of the small miss-calculations. Also, if using a Bowden tube, you will need more filament to push the green to the hot-end anyway. 11)Print away!
Re: Impression multicolore avec une buse July 18, 2013 07:07PM |
Traduction
Toutefois, si vous voulez faire cela avec tout autre chose que la configuration sus-mentionnée, faites comme suit :
1) Mesurez la quantité de filament que votre machine utilise par E dans votre g-code. Expérimentez, en faisant extruder 1000E, 500E ou 5000E, puis en mesurant la quantité de filament qui est passé par l'extrudeur. Ainsi vous saurez combien de millimètres correspondent à 1000E par exemple.
2) Générez le gcode pour votre objet (notez que vous devez ajouter du remplissage -infill- pour cette impression, notamment pour supporter la tige / le support -stem-). Ouvrez-le et notez la valeur Z dans les dernières lignes. Cette valeur représente la hauteur de votre objet en mm.
3) Faites le calcul suivant : (hauteur totale de l'objet) / 47 x 6 = la hauteur (ou l'épaisseur) de chaque couleur pour votre objet.
4) Maintenant que vous avez la hauteur pour chaque couleur, vous pouvez déterminer à quelle hauteur de votre objet elles commenceront. Notez la hauteur de départ pour chaque couleur.
5) Ensuite, vous pouvez à nouveau examiner les valeurs Z de votre g-code. D'abord, trouvez le point où Z est le plus près de l'épaisseur de votre première couleur. Par exemple, si l'épaisseur est de 8,04 mm, cherchez une valeur entre Z8.02 et Z8.06. Choisissez la valeur la plus près.
6) Quand vous avec choisi la bonne valeur en Z, notez la valeur E sur la même ligne.
7) Répétez l'étape 6 jusqu'à la couleur verte. Notez la valeur en E correspondante à chaque valeur en Z.
8) Calculez la différence en nombres E pour chaque couche de couleur.
9) Enfin, divisez ces différences en nombres E par le ratio mm/E que vous avez calculé à l'étape 1. Ceci vous donnera la longueur de filament pour chaque couleur.
10) Coupez les filaments aux longueurs correctes et joignez-les de préférence avant d'imprimer avec la méthode de votre choix. Si vous ne l'avez jamais fait auparavant, informez-vous auprès des gens qui l'ont fait. Note : vous ne devriez pas couper le filament vert, parce que si vous le faites, vous risquez de manquer de filament pour l'impression s'il y a eu des erreurs de calculs. De plus, si vous utilisez un tube Bowden, vous aurez besoin de davantage de filament pour pousser le vert dans la hot end.
11) Imprimez !
Re: Impression multicolore avec une buse July 19, 2013 07:43AM |
Re: Impression multicolore avec une buse July 19, 2013 08:01AM |
Re: Impression multicolore avec une buse July 19, 2013 08:35AM |
Re: Impression multicolore avec une buse July 19, 2013 11:20AM |
Re: Impression multicolore avec une buse July 24, 2013 07:18AM |
Re: Impression multicolore avec une buse July 25, 2013 01:19AM |
