LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE August 07, 2013 09:09AM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE August 07, 2013 09:31AM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE August 07, 2013 10:13AM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE August 08, 2013 04:07AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE August 08, 2013 05:07AM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE August 15, 2013 05:27AM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE August 15, 2013 01:18PM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE August 15, 2013 02:14PM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE August 15, 2013 02:23PM |
M303 S200 C5
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE September 19, 2013 05:39PM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE September 19, 2013 11:41PM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE September 22, 2013 04:49PM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE September 23, 2013 03:51AM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE September 23, 2013 04:19AM |
// PID settings: // Comment the following line to disable PID and enable bang-bang. #define PIDTEMP #define PID_MAX 255 // limits current to nozzle; 255=full current #ifdef PIDTEMP //#define PID_DEBUG // Sends debug data to the serial port. //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX #define PID_INTEGRAL_DRIVE_MAX 255 //limit for the integral term #define K1 0.95 //smoothing factor withing the PID #define PID_dT ((16.0 * 8.0)/(F_CPU / 64.0 / 256.0)) //sampling period of the // If you are using a preconfigured hotend then you can use one of the value sets by uncommenting it // Ultimaker #define DEFAULT_Kp 22.2 #define DEFAULT_Ki 1.08 #define DEFAULT_Kd 114 // Makergear // #define DEFAULT_Kp 7.0 // #define DEFAULT_Ki 0.1 // #define DEFAULT_Kd 12 // Mendel Parts V9 on 12V // #define DEFAULT_Kp 63.0 // #define DEFAULT_Ki 2.25 // #define DEFAULT_Kd 440 #endif // PIDTEMPIl suffit de mettre les valeurs que t'a donné Marlin comme suit à la place de celle d'Ultimaker
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE September 23, 2013 06:48AM |
Re: LED ROUGE SUR CARTE RAMPS LORS DE LA CHAUFFE February 02, 2015 05:09AM |
