AutoLeveling: Z monte pas entre 2 probings June 22, 2014 10:51AM |
Re: AutoLeveling: Z monte pas entre 2 probings July 02, 2014 11:42PM |
Re: AutoLeveling: Z monte pas entre 2 probings July 03, 2014 02:39AM |
Re: AutoLeveling: Z monte pas entre 2 probings July 03, 2014 05:59AM |
Re: AutoLeveling: Z monte pas entre 2 probings July 03, 2014 11:19AM |
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
Re: AutoLeveling: Z monte pas entre 2 probings July 03, 2014 02:09PM |
// these are the offsets to the probe relative to the extruder tip (Hotend - Probe)
#define X_PROBE_OFFSET_FROM_EXTRUDER -15
#define Y_PROBE_OFFSET_FROM_EXTRUDER -7.30
#define Z_PROBE_OFFSET_FROM_EXTRUDER -16
#define Z_RAISE_BEFORE_HOMING 4 // (in mm) Raise Z before homing (G28) for Probe Clearance.
// Be sure you have this distance over your Z_MAX_POS in case
#define XY_TRAVEL_SPEED 8000 // X and Y axis travel speed between probes, in mm/min
#define Z_RAISE_BEFORE_PROBING 20 //How much the extruder will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 10 //How much the extruder will be raised when traveling from between next probing points
Re: AutoLeveling: Z monte pas entre 2 probings July 03, 2014 02:10PM |
Re: AutoLeveling: Z monte pas entre 2 probings July 03, 2014 03:39PM |
