Rendre une Reprap autonome November 12, 2014 07:36AM |
Re: Rendre une Reprap autonome November 12, 2014 08:12AM |
Re: Rendre une Reprap autonome November 12, 2014 08:39AM |
Re: Rendre une Reprap autonome November 12, 2014 12:16PM |
Re: Rendre une Reprap autonome November 12, 2014 02:06PM |
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-ar: unable to rename 'core.a'; reason: Permission denied core.a(main.cpp.o): In function `main': C:\Program Files\Arduino\hardware\arduino\cores\arduino/main.cpp:34: undefined reference to `setup' C:\Program Files\Arduino\hardware\arduino\cores\arduino/main.cpp:44: undefined reference to `loop' U8glib\U8glib.cpp.o: In function `U8GLIB::initRW8Bit(_u8g_dev_t*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)': C:\Documents and Settings\Administrateur2\Mes documents\Arduino\libraries\U8glib/U8glib.cpp:74: multiple definition of `U8GLIB::initRW8Bit(_u8g_dev_t*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)' U8glib.cpp.o:C:\DOCUME~1\Administrateur2\Local Settings\Temp\build1478117906385437292.tmp/U8glib.cpp:74: first defined here c:/program files/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions U8glib\U8glib.cpp.o: In function `U8GLIB::init8BitFixedPort(_u8g_dev_t*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)': C:\Documents and Settings\Administrateur2\Mes documents\Arduino\libraries\U8glib/U8glib.cpp:67: multiple definition of `U8GLIB::init8BitFixedPort(_u8g_dev_t*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)' U8glib.cpp.o:C:\DOCUME~1\Administrateur2\Local Settings\Temp\build1478117906385437292.tmp/U8glib.cpp:67: first defined here U8glib\U8glib.cpp.o: In function `U8GLIB::init8Bit(_u8g_dev_t*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)': C:\Documents and Settings\Administrateur2\Mes documents\Arduino\libraries\U8glib/U8glib.cpp:61: multiple definition of `U8GLIB::init8Bit(_u8g_dev_t*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)' U8glib.cpp.o:C:\DOCUME~1\Administrateur2\Local Settings\Temp\build1478117906385437292.tmp/U8glib.cpp:61: first defined here U8glib\U8glib.cpp.o: In function `U8GLIB::initI2C(_u8g_dev_t*, unsigned char)': C:\Documents and Settings\Administrateur2\Mes documents\Arduino\libraries\U8glib/U8glib.cpp:54: multiple definition of `U8GLIB::initI2C(_u8g_dev_t*, unsigned char)' U8glib.cpp.o:C:\DOCUME~1\Administrateur2\Local Settings\Temp\build1478117906385437292.tmp/U8glib.cpp:54: first defined here U8glib\U8glib.cpp.o: In function `U8GLIB::initHWSPI(_u8g_dev_t*, unsigned char, unsigned char, unsigned char)': C:\Documents and Settings\Administrateur2\Mes documents\Arduino\libraries\U8glib/U8glib.cpp:48: multiple definition of `U8GLIB::initHWSPI(_u8g_dev_t*, unsigned char, unsigned char, unsigned char)' U8glib.cpp.o:C:\DOCUME~1\Administrateur2\Local Settings\Temp\build1478117906385437292.tmp/U8glib.cpp:48: first defined here U8glib\U8glib.cpp.o: In function `U8GLIB::initSPI(_u8g_dev_t*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)': C:\Documents and Settings\Administrateur2\Mes documents\Arduino\libraries\U8glib/U8glib.cpp:42: multiple definition of `U8GLIB::initSPI(_u8g_dev_t*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)' U8glib.cpp.o:C:\DOCUME~1\Administrateur2\Local Settings\Temp\build1478117906385437292.tmp/U8glib.cpp:42: first defined hereJe vais tenter de débuger ça tout à l'heure.
Re: Rendre une Reprap autonome November 12, 2014 05:00PM |
Re: Rendre une Reprap autonome November 12, 2014 05:31PM |
Re: Rendre une Reprap autonome November 12, 2014 05:49PM |
Re: Rendre une Reprap autonome November 12, 2014 05:56PM |
Re: Rendre une Reprap autonome November 13, 2014 04:04AM |
Re: Rendre une Reprap autonome November 13, 2014 05:26AM |
Re: Rendre une Reprap autonome November 13, 2014 06:00AM |
Re: Rendre une Reprap autonome November 13, 2014 07:17AM |
jhd
Télécharge le marlin du github et un logiciel d analyse comparative genre winmerge.
Grâce a winmerge tu copie les modifs de paramétrage du firmware proprio vers le complet.
Au max ca va te prendre 30minutes et t auras une base saine avec ton parametrage
Re: Rendre une Reprap autonome November 13, 2014 12:21PM |
Re: Rendre une Reprap autonome November 14, 2014 07:13AM |
//LCD and SD support //#define ULTRA_LCD //general lcd support, also 16x2 //#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) #define SDSUPPORT // Enable SD Card Support in Hardware Console3. j'ai décommenté la ligne de déclaration de l'écran :
// The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC // [reprap.org] // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLERVoyez-vous une erreur ? Un oubli ? Serait-ce mon écran "neuf" qui est HS ?
Re: Rendre une Reprap autonome November 14, 2014 09:56AM |
Re: Rendre une Reprap autonome November 14, 2014 12:46PM |
Re: Rendre une Reprap autonome November 14, 2014 04:53PM |
Re: Rendre une Reprap autonome November 15, 2014 04:58AM |
Re: Rendre une Reprap autonome November 15, 2014 07:21AM |
