servo double extruder November 20, 2014 10:35AM |
Re: servo double extruder November 20, 2014 10:53AM |
Re: servo double extruder November 20, 2014 11:01AM |
Re: servo double extruder November 21, 2014 09:03AM |
Re: servo double extruder November 21, 2014 09:05AM |
Re: servo double extruder November 21, 2014 12:07PM |
Re: servo double extruder November 21, 2014 04:28PM |
Re: servo double extruder November 22, 2014 03:34AM |
Strofe
Bonsoir
7. already supported by Marlin firmware (choose "#define MOTHERBOARD 34")
8. easy to adapapt to other firmware (e.g. Sprinter: just change "#define FAN_PIN 6" in "pins.h")
Yakalire
A+
Re: servo double extruder November 22, 2014 06:07AM |
cliclac90
Merci Strofe, mais j'avais bien lu cela, j'ai bien mis "define MOTHERBOARD 34" mais ca marche pas.
#ifndef MOTHERBOARD #define MOTHERBOARD 34 #endif
Re: servo double extruder November 22, 2014 06:19AM |
Re: servo double extruder November 23, 2014 03:43PM |
Re: servo double extruder November 23, 2014 04:48PM |
Re: servo double extruder November 24, 2014 03:34AM |
Re: servo double extruder November 24, 2014 04:36AM |
Re: servo double extruder November 24, 2014 04:48AM |
Re: servo double extruder November 24, 2014 07:28AM |
Re: servo double extruder November 24, 2014 07:53AM |
suitengu
Exactement 4 servos à l'origine et pas mal plus en bidouillant. Il faut les déclarer à la fin de configuration.h
Après ça marche avec m280 P"num du servo" S"angle". Si tu veux aller plus loin il est aussi possible d'aller dans marlin_main.cpp pour modifier ce que font les Gcodes. C'est possible de faire faire marcher le servo automatiquement à la commande de changement d'outil (comme avec le servo de la sonde de l'auto bed leveling).
Re: servo double extruder November 25, 2014 01:38AM |
Re: servo double extruder November 25, 2014 05:03AM |
Re: servo double extruder November 25, 2014 01:27PM |
Re: servo double extruder November 25, 2014 06:03PM |
Re: servo double extruder November 26, 2014 03:35AM |
Re: servo double extruder November 26, 2014 04:00AM |
Re: servo double extruder November 26, 2014 09:01AM |
blacline
Tres sympa!!
A tu penser au fixations des plaques qui bouche l'extrudeur non utilisé?
Mortalus25
Quel type de servo tu vas utiliser ? Comptes tu le laisser sous tension tout le temps de l'impression ?
