E3DV6 sur Prusa I3 March 15, 2015 05:07AM |
Re: E3DV6 sur Prusa I3 March 15, 2015 06:42AM |
Re: E3DV6 sur Prusa I3 March 15, 2015 07:21AM |
Re: E3DV6 sur Prusa I3 March 15, 2015 07:53AM |
Re: E3DV6 sur Prusa I3 March 15, 2015 08:09AM |
Re: E3DV6 sur Prusa I3 March 15, 2015 10:00AM |
Re: E3DV6 sur Prusa I3 March 15, 2015 05:17PM |
Re: E3DV6 sur Prusa I3 March 16, 2015 06:45AM |
Re: E3DV6 sur Prusa I3 March 16, 2015 06:59AM |
je ne comprends pas bien ... la E3DV6 ne serait pas bien selon toi ?Quote
shoutr
si tu veux du tout metal, oriente toi plutot vers de l'hexagon. Ou si tu veux du sur et certain que ça marche (pla, abs en faisant gaffe), prend de la jhead. regarde les forums E3D v6 sur leur site, tu comprendra pourquoi.
Re: E3DV6 sur Prusa I3 March 16, 2015 07:12AM |
Re: E3DV6 sur Prusa I3 March 16, 2015 08:15AM |
Re: E3DV6 sur Prusa I3 March 17, 2015 06:36AM |
Re: E3DV6 sur Prusa I3 March 17, 2015 06:44AM |
pierrelesek
Zavashier
J'en suis à ma quatrième E3D fabriquée aux cotes : 1xV5 et 3xV6. Rien à signaler ici.
On peut dire que tu es chanceux, car tout les problèmes rapportés sur l'IRC par rapport à la V6 ...
Re: E3DV6 sur Prusa I3 March 17, 2015 06:51AM |
Re: E3DV6 sur Prusa I3 March 17, 2015 07:52AM |
shoutr
ouais, genre:
client:
Looks like my issue is solved for now. Turns out I had a burr in my nozzle. I purchased an extra nozzle to have on hand to swap it out when I wanted to clean the current nozzle. I decided to switch them out to acetone soak the original nozzle. I've had no jamming issues since then. I ran a .04mm drill through the original nozzle and found a burr in it. It wasn't just filament and almost broke my drill bit. With a little work, I was able to get it smoothed out.
vendeur:
It's great that you found the problem and no more jamming issues!
Re: E3DV6 sur Prusa I3 March 17, 2015 01:56PM |
Re: E3DV6 sur Prusa I3 March 17, 2015 02:16PM |
Re: E3DV6 sur Prusa I3 March 17, 2015 02:17PM |
Re: E3DV6 sur Prusa I3 March 17, 2015 02:37PM |
Re: E3DV6 sur Prusa I3 March 17, 2015 02:53PM |
Re: E3DV6 sur Prusa I3 March 17, 2015 02:54PM |
Wow, il y a des montées des testostérone ici en ce moment. T'as eu des soucis avec une E3D ? Il faut rester calme.Quote
Cammi
Ok t'a une E3d que t'as fabriqué toi même et tu juge la e3d originale d'après les plans que tu as repris?
y'a un soucis au niveau de l'usinage du heatbreak chez e3d ou leur sous traitant. Ca a été démontré point barre. Le fait que le heatbreak que TU as fabriqué fonctionne ne prouve en rien que ceux de chez E3d soient bons.
Faudrait voir a pas tout mélanger.
Re: E3DV6 sur Prusa I3 March 17, 2015 03:05PM |
Zavashier
Il y a même des copies chinoises à moins de 15€, que demande le peuple ?
Re: E3DV6 sur Prusa I3 March 17, 2015 04:07PM |
Re: E3DV6 sur Prusa I3 March 18, 2015 10:58AM |
Re: E3DV6 sur Prusa I3 March 18, 2015 05:05PM |
Re: E3DV6 sur Prusa I3 March 19, 2015 04:16AM |
