Problème ventilateur extruder December 11, 2015 04:36PM |
Re: Problème ventilateur extruder December 11, 2015 05:13PM |
// Increase the FAN pwm frequency. Removes the PWM noise but increases heating in the FET/Arduino //#define FAST_PWM_FAN // Use software PWM to drive the fan, as for the heaters. This uses a very low frequency // which is not as annoying as with the hardware PWM. On the other hand, if this frequency // is too low, you should also increment SOFT_PWM_SCALE. //#define FAN_SOFT_PWM // Incrementing this by 1 will double the software PWM frequency, // affecting heaters, and the fan if FAN_SOFT_PWM is enabled. // However, control resolution will be halved for each increment; // at zero value, there are 128 effective control positions. #define SOFT_PWM_SCALE 0
Re: Problème ventilateur extruder December 11, 2015 05:38PM |
Re: Problème ventilateur extruder December 11, 2015 05:48PM |
Re: Problème ventilateur extruder December 11, 2015 05:53PM |
Re: Problème ventilateur extruder December 11, 2015 06:37PM |
Re: Problème ventilateur extruder December 12, 2015 01:22PM |
Re: Problème ventilateur extruder December 13, 2015 06:09AM |
Re: Problème ventilateur extruder December 13, 2015 06:13AM |
Re: Problème ventilateur extruder December 13, 2015 06:16AM |
Re: Problème ventilateur extruder December 13, 2015 07:14AM |
Il faut le branché en 12V! C'est impératif et cela a déjà été dit a plusieurs reprise.Quote
Il n'est pas branché en 12v constant sinon à 100% il refroidit trop la buse et a 30% le filament coince
Re: Problème ventilateur extruder December 13, 2015 09:03AM |
