Sur-extrusion première couche May 30, 2016 07:35AM |
Re: Sur-extrusion première couche May 30, 2016 09:12AM |
Re: Sur-extrusion première couche May 30, 2016 10:36AM |
Re: Sur-extrusion première couche May 30, 2016 11:46AM |
Re: Sur-extrusion première couche May 30, 2016 02:51PM |
Re: Sur-extrusion première couche May 30, 2016 04:16PM |
Re: Sur-extrusion première couche May 30, 2016 08:36PM |
Re: Sur-extrusion première couche May 31, 2016 02:51AM |
Re: Sur-extrusion première couche May 31, 2016 04:08AM |
Re: Sur-extrusion première couche May 31, 2016 09:59AM |
Re: Sur-extrusion première couche May 31, 2016 10:10AM |
Re: Sur-extrusion première couche May 31, 2016 11:47AM |
Re: Sur-extrusion première couche June 01, 2016 03:59AM |
Re: Sur-extrusion première couche June 01, 2016 12:14PM |
Re: Sur-extrusion première couche June 02, 2016 03:16AM |
Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M109 S{print_temperature} ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M82 ;set extruder to absolute mode M107 ;start with the fan off G28 G29 G1 Z15.0 F{travel_speed} ;move the platform down 15mm G92 E0 ;zero the extruded length G1 F200 E15 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M117 Printing...
Re: Sur-extrusion première couche June 02, 2016 10:51AM |
Re: Sur-extrusion première couche June 04, 2016 05:14PM |
Re: Sur-extrusion première couche June 05, 2016 04:21PM |
