Probleme extruder Moteur ou marlin bref j'en sais rien June 18, 2016 12:10PM |
#define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
//// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {2000, 2000, 150, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {100, 100, 4000, 100} //550 default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 3, 25} //25 (mm/sec) #define DEFAULT_MAX_ACCELERATION {3000,3000,100,1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 2000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 2000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 19, 2016 12:38AM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 19, 2016 05:43AM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 19, 2016 10:30AM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 20, 2016 01:09PM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 21, 2016 02:39AM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 21, 2016 06:51AM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 21, 2016 08:47AM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 21, 2016 10:35AM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 21, 2016 12:18PM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 21, 2016 01:43PM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 21, 2016 02:41PM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 21, 2016 03:05PM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 21, 2016 04:30PM |
Re: Probleme extruder Moteur ou marlin bref j'en sais rien June 23, 2016 12:21AM |
