Hello,
I'm really glad, that I managed it to print my first part on a RepRap with the first Generation Electronics. For this I used the Hostsoftware 0.9 which worked almost fine. But I mentioned that the building process is improved from Hostsoftware to Hostsoftware. But when I start a building process in the Hostsoftware 1.0 the XY-Movement is at it's highest speed.
I also got problems with moving the axis in the XYZ Window.
The same behavior in Linux and Windows, except that using the Linux Hostsoftware no outline is printed, even if I adjust the value for it higher than one.
I would be apreciate for any ideas and answers.
Thanks
Maurice
