RepRap Host Will not start
Posted by swighton
November 18, 2009 11:54PM
Tonight I installed the 5D firmware on my reprap motherboard and extruder controller, and am tweaking the machine to get ready to print. The host software was launching no problem, the RepRap was taking commands, the extruder was working etc. I stopped the program and restarted it but now it won't start. The first time it tried to load the host it said something to the effect of "since you have changed your machine type the host will have to restart" Now It loads the command prompt but then just gives me this.
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
comms: tx 0->0: 0 ( = 0 ) [0.002s/-1258606027994ms]
comms: tx 0->0: 0 ( = 0 ) [0.411s/409ms]
comms: tx 0->0: 0 ( = 0 ) [0.819s/408ms]
comms: tx 0->0: 0 ( = 0 ) [1.227s/408ms]
comms: tx 0->0: 0 ( = 0 ) [2.035s/808ms]
comms: tx 0->0: 0 ( = 0 ) [2.847s/812ms]
comms: tx 0->0: 0 ( = 0 ) [3.257s/410ms]
comms: tx 0->0: 0 ( = 0 ) [4.485s/1228ms]
comms: tx 0->0: 0 ( = 0 ) [4.894s/409ms]
comms: tx 0->0: 0 ( = 0 ) [5.704s/810ms]
comms: tx 0->0: 0 ( = 0 ) [6.512s/808ms]
comms: tx 0->0: 0 ( = 0 ) [6.920s/408ms]
comms: tx 0->0: 0 ( = 0 ) [7.328s/408ms]
comms: tx 0->0: 0 ( = 0 ) [8.136s/808ms]
comms: tx 0->0: 0 ( = 0 ) [8.544s/408ms]
comms: tx 0->0: 0 ( = 0 ) [9.352s/808ms]
comms: tx 0->0: 0 ( = 0 ) [10.723s/1371ms]
comms: tx 0->0: 0 ( = 0 ) [11.133s/410ms]
etc...
When I don't have the reprap attached to the computer the host loads fine. Does anyone know what is causing this and what I need to do to fix it?
Thanks
Edited 1 time(s). Last edit at 11/18/2009 11:56PM by swighton.
Re: RepRap Host Will not start
November 19, 2009 01:09AM
Solved problem - for anyone else with this problem, the host software made a new directory in my documents called .reprap with a reprap.properties file. When I deleted the file everything worked again.
December 26, 2009 11:55AM
I just had this problem too, I accidentally clicked on "Print on SNAP RepRap".
If you don't want to loose all your configuration settings, edit the reprap.properties file and look for
RepRap_Machine=SNAPRepRap
change it to:
RepRap_Machine=GCodeRepRap
FiveD Firmware fork (supports Arduino Mega): [github.com]
reprapsource.com
