Extruder Heat Profiler reaches max temperature and aborts before outputting data. June 29, 2008 11:27PM |
mm)=15
mm)=20
mm)=20
mm)=0
mm)=300
mm)=15
mm)=0
mm)=-17.3|
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. June 30, 2008 05:59AM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 01, 2008 07:23PM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 06, 2008 08:03PM |
have a spreadsheet left over of power settings and their corresponding temperatures, please post it. That would help me a lot.
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 06, 2008 09:14PM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 08, 2008 12:03AM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 08, 2008 04:46AM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 08, 2008 05:05PM |
One of them will probably lead to the solution.
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 08, 2008 05:28PM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 08, 2008 06:15PM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 09, 2008 03:08PM |
Admin Registered: 19 years ago Posts: 1,487 |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 09, 2008 07:58PM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 10, 2008 03:59AM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 10, 2008 04:47PM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 11, 2008 04:09AM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 11, 2008 12:49PM |
It's mentioned here: [reprap.org]|
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 11, 2008 04:48PM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 12, 2008 04:08AM |
Re: Extruder Heat Profiler reaches max temperature and aborts before outputting data. July 13, 2008 11:04AM |
