Do you find that filament spool to be useful? I printed the exact same one out myself, but I found that there was too much friction (too many tight turns) for the extruder motor to pull the filament off the spool.
I think I need to re-jig it so that the spool is turned around 90 degrees, and feeding straight down into the extruder.
___________________________________________________________________________
systematictechnology.net
