power supply
Posted by Dylan
power supply
May 23, 2008 01:05AM
I don't have a lot of experience with doing the power convertions.
I know my power supply can handle up to 18.5amps (16a on red wire alone), but I've read on here that it's the tip110 that will screw with me if I try to draw too much power.
I'm trying to get as much power into the nichrome wire as I can for higher and faster heat but I want to be safe too.
Any suggestions or help would be appreciated.
thanks
Dylan
Re: power supply
May 23, 2008 04:25AM
About 18W seems to be all that is needed from the heater, even for high temperature and fast extrusion. It takes less than 2 minutes to warm up, which is nothing compared to how long it takes to make anything.
A 6R heater will give about 18W and draw less than 2A.
Increasing the power any more just makes it more dangerous. If you have a fault which leaves it on, the PTFE will give off poisonous fumes above 300C I believe.
Re: power supply
May 23, 2008 02:10PM
Ok, thanks for the info. I guess I'll stay at the 6ohm reccomendation then.
thanks.
