i am trying to fix 2 reprap version darwin 1.0 that freshmen of a computer engineering course try to build but just broke, so i am in need of a little help.
my current issues is that when i try to control the stepper motors for movement they either only move in one direction or (in the case of the z axis) the axis reverse the direction from moving up once the stepper exercise slider bar gets past so high. ( i think 32k ticks)
i am using the DVD image version 0.6 software fully installed. i don't think it is the software because i was able to get all the correct movement on the first of the 2 repraps but had frictions issues so i began work on the another one. with the z-idler pulley set i was able to get the second of the 2 repraps able to move without issues but not under control of the boards
i even tried moving the board from the first of the 2 repraps (functional movement but too much friction) to the second reprap, where there is still control issues.
any advise?
and is there a link for the wiring set up between the boards someone could link me just so i have confirm i am using the correct set up?
after further testing i have determine that my x and y axis are working correctly but my z axis still rolls over at little over 32516 ticks...any ideas what the issue could be?
Edited 1 time(s). Last edit at 11/06/2008 12:15PM by etgrh18.
