MOFSET Choice Help
Posted by Chris Martin
MOFSET Choice Help
May 05, 2011 03:18PM
I asked this over in the RAMPS forum and received a few conflicting answers. This is probably more appropriate for this forum.
RAMPS requires the use of the STP55NF06L TO-220 N-type MOSFET. The problem is that it is a special order through digikey which is a major electronics supplier here in the US. The STP55NF06 is a stocked product but my real question is what the true requirements for this MOSFET are. I am no electronics whiz but was hoping someone could give the major requirements and then any MOSFET that meets that spec could be used.
Thanks in advance.
Re: MOFSET Choice Help
May 05, 2011 06:18PM
If i recall correctly some math i did for the same thing:
- STP55NF06L is 60V and can do like ~8A in still air, and
- IRL3803 is 30V and can do like ~16A in still air and with approx 4 times less disipation on it
The IRL3803 is logic level in all variants and on stock on several packages at digikey. There are probably lots of other choices aswell.
I guess that the fet ideally should:
- be logic level and
- be able to switch the working current in still air / without heatsink - for the best. Which usually translates in a low rds(on) value: the power that the fet needs to disipate would be Iworking^2 * rds(on).
To approximate how much current it can switch in still air / w/o sink, i think it is
= SQRT [ (Tempmax / R-thj-amb ) / (pwrdisipated@25 / Imax ^2) ]
and all of these 4 values can be found in any fet datasheet. Double check the formula though. I think this value should be, with a fair margin, bigger than the current expected to work with.
I hope the above is fairly accurate. Good luck smiling smiley
May 05, 2011 06:53PM
