0.1ohm resistors for heated bed? August 12, 2011 12:36PM |
Re: 0.1ohm resistors for heated bed? August 12, 2011 01:02PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: 0.1ohm resistors for heated bed? August 12, 2011 02:48PM |
Admin Registered: 16 years ago Posts: 13,908 |
Re: 0.1ohm resistors for heated bed? August 12, 2011 03:16PM |
Re: 0.1ohm resistors for heated bed? August 13, 2011 04:10AM |
This is more than your motherboard can supply but with a relay it may still work.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: 0.1ohm resistors for heated bed? August 13, 2011 01:58PM |
Re: 0.1ohm resistors for heated bed? August 13, 2011 02:42PM |
Re: 0.1ohm resistors for heated bed? August 14, 2011 04:13AM |
> A decent electronics can deliver 12 amps directly
> winking smiley
Your totally correct. I don't know what I was thinking about. The FETs on RAMPS and Sanguinololu which I have both of are rated to 55A.
Re: 0.1ohm resistors for heated bed? August 24, 2011 10:02AM |
