Communication Melzi Ardentissimo June 05, 2012 03:23AM |
root@reprap:/home/reprap/Printrun# python2 pronterface.py Connecting... Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14665, in lambda event: event.callable(*event.args, **event.kw) ) File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 1850, in AppendText return _controls_.TextCtrl_AppendText(*args, **kwargs) File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode return codecs.utf_8_decode(input, errors, True) UnicodeDecodeError: 'utf8' codec can't decode byte 0xe1 in position 0: invalid continuation byte Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14665, in lambda event: event.callable(*event.args, **event.kw) ) File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 1850, in AppendText return _controls_.TextCtrl_AppendText(*args, **kwargs) File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode return codecs.utf_8_decode(input, errors, True) UnicodeDecodeError: 'utf8' codec can't decode byte 0xe8 in position 2: invalid continuation byte Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14665, in lambda event: event.callable(*event.args, **event.kw) ) File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 1850, in AppendText return _controls_.TextCtrl_AppendText(*args, **kwargs) File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode return codecs.utf_8_decode(input, errors, True) UnicodeDecodeError: 'utf8' codec can't decode byte 0x9b in position 6: invalid start byte Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14665, in lambda event: event.callable(*event.args, **event.kw) ) File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 1850, in AppendText return _controls_.TextCtrl_AppendText(*args, **kwargs) File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode return codecs.utf_8_decode(input, errors, True) UnicodeDecodeError: 'utf8' codec can't decode byte 0xf8 in position 1: invalid start byte Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14665, in lambda event: event.callable(*event.args, **event.kw) ) File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 1850, in AppendText return _controls_.TextCtrl_AppendText(*args, **kwargs) File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode return codecs.utf_8_decode(input, errors, True) UnicodeDecodeError: 'utf8' codec can't decode byte 0xf1 in position 6: invalid continuation byte
Re: Communication Melzi Ardentissimo June 06, 2012 01:49PM |
Re: Communication Melzi Ardentissimo June 06, 2012 02:25PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Communication Melzi Ardentissimo June 07, 2012 04:40AM |
