i have stepper motor - 17HS19-1684S, can u suggest me a driver which will work with my stepper motor? ( i want connect this driver to my arduino)
Thank you!
Stepper motor specs:
Frame size 42 x 42mm - NEMA 17
1.8 degree step angle
Length 47mm
Holding torque 44 N.cm (4.4kg.cm, 62oz.in)
Voltage 2.8V
Current/Phase 1.68A
Resistance/Phase 1.65ohm
Inductance/Phase 2.8mH
Inertia 68g.cm
Bipolar, 4-wire
Weight 0.35kg
Step Angle Accuracy ±5%(full step,no load)
Resistance Accuracy ±10%
Inductance Accuracy ±20%
Temperature Rise 80℃Max.(rated current,2 phase on)
Ambient Temperature -10℃-+50℃
Insulation Resistance 100MΩMin. 500VDC
Dielectric Strength 500VAC for one minute
Shaft Radial Play 0.02Max.(450 g-load)
Shaft Axial Play 0.08Max.(450 g-load)
