First Motherboard February 20, 2014 02:26AM |
Re: First Motherboard February 20, 2014 06:55AM |
Re: First Motherboard February 20, 2014 09:25AM |
Re: First Motherboard February 21, 2014 02:50AM |
Re: First Motherboard March 06, 2014 04:23PM |
Re: First Motherboard March 06, 2014 05:18PM |
That's why you can run down to your local RadioShack and pick up this guy for a few bucks. Takes care of a lot of the problem. A fan blowing on the RAMPS/heatsink/stepper drivers isn't going to hurt either...and is generally recommended for maximum lifespan so I've seen recommended.Quote
ndujar
Hmmmm..my only advice against RAMPS is how it deals with its MOSFETS...it has a flaw in design that makes them enter in resonance with the hotbed and, unless they are quite powerful, they tend to fry:
Re: First Motherboard March 07, 2014 05:03AM |
ndujar
[*] [www.buildlog.net]
[*] [www.soliforum.com]
[*] [forums.robo3dprinter.com]
I have one myself and got it burnt in the first day...actually is just a matter of luck whether your provider has assembled the correct type of MOSFET or not. So, just for precaution, I would warn you to get some with the specifications of any of the above links, just in case.
However, for a first printer, an even better solution is to avoid ABS and focus in PLA. As PLA doesn't require of a hotbed you will be safely printing for a long time.
Happy printing!
Re: First Motherboard March 07, 2014 08:51AM |
waitaki
ndujar
Happy printing!
What?
Re: First Motherboard March 07, 2014 08:39PM |
Re: First Motherboard March 08, 2014 12:17PM |
The isolation is only needed when there are different power supplies. The isolation adds delays to any signal, and thats no good, so isolation is a trade-off only to be used when necessary. If it would be only positive aspects to this, then all arduino boards would have optocouplers built in on all gpio. Also the guys behind ramps are guys which were in reprap, even admins, and did alot of things and while there is no need to emphasize that, they do have background and experience on their side, and i do respect and value that and their work and contributions. Generally i have nothing against criticism of anybody, but except with the part where some try to raise themselves this way. I dont mean to be a put down, but on some level, at least in my book, you have to do something first, and brag about it later. Even chickens do lay egg first, and start yakking after. Vice-versa doesnt quite work the same. If you want to learn from somebody, really take a good loook.Quote
In fact neither is there the slightest isolation between the power part and the control part (another design flaw of the important RAMPS but that would require a complete redesign) it's more than likely shit and engage the interference by mass to other areas of the circuit. All very cool going. , we think it's a pretty reasonable explanation for why they were going to take the ass MOSFETs. Honestly I find it rather unfortunate when a f**king diode cents worth. And some optocouplers not worth much more. Apparently seen I think I will review the entire design of the RAMPS to see what surprises you ... In order to solve the problem going to an electronics store and a couple ye pilláis certain power diode.
Ramps mosfet is a hexfet and if voltage gets too high it breaks down and conducts to ground. Check the datasheet symbol right side of that mosfet symbol and compare to the symbol of a the diodes, see which one matches, and read a bit about those. Their breakdown is mentioned in datasheet. It appears to coincide with the absolute max Vds value, but it may be a confusion as to which determines which, and what happens over the value. One would think the diode is there because it tries to protect the mosfet above its own max vds. I would rather have it the other way around. My pov is that the absolute max value is exactly that determined by the min breakdown, because above that point the mosfet simply no longer works because in breakdown mode the mosfet is simply entirely bypassed to ground. Absolute max in this case may not mean it immediately blows up. It doesnt mean it will explode, it means that diode creates a short to ground for voltages above that value, intended to sink transients to ground. If the transient is too big, temperatures too high, perhaps that diode will fail at some point, and will blow up eventually, but for ramps breakdown starts at 60v minimum, so perhaps wont blow up at 70v, will it. Not all mosfets work like so, but those do, and i am not against the freewheel diode, that is good, and the arguments for that are good, and its worth having, but its just not an universal panacea and neither lacking it is the root of all evil.Quote
The MOSFET ramps joint endure maximum 60V.
Ofc they do, they are meant to prove a point. That was exactly the point. But remember they are simulations. Read the datasheet of that mosfet: in practice, you wont get 70V transient forming across a body diode with 30V breakdown rating.Quote
Up in the simulations, ringing (oscillations) appear horrible.
Now thats the part which is interesting and which got me to post in the first place. Over 400 times per second. Priceless. Dunno where the numbers comes from, or which tool measured that, but that would be interesting to know.Quote
Re: First Motherboard March 08, 2014 01:12PM |
Re: First Motherboard March 08, 2014 02:18PM |
Re: First Motherboard March 08, 2014 02:40PM |
Re: First Motherboard March 08, 2014 03:20PM |
Re: First Motherboard March 08, 2014 03:58PM |
Re: First Motherboard March 08, 2014 05:05PM |
NoobMan
// If your bed has low resistance e.g. .6 ohm and throws the fuse you can duty cycle it to reduce the
// average current. The value should be an integer and the heat bed will be turned on for 1 interval of
// HEATER_BED_DUTY_CYCLE_DIVIDER intervals.
//#define HEATER_BED_DUTY_CYCLE_DIVIDER 4
Dunno how this is computed but looks like something i would stay away from, instead why not use a use higher rating fuse or a slow-blow fuse, i am not sure i understand the motivation of this.
Re: First Motherboard March 08, 2014 06:49PM |
Re: First Motherboard March 08, 2014 07:19PM |
Re: First Motherboard March 09, 2014 05:14AM |
