Power supply input
Posted by Dom22
Power supply input
March 24, 2014 01:17PM
I have an LED power supply 12V-400W. The label specifies Input 170-260V - 50/60hz. The problem is I am in North America with 110/120V input. Will it work?
Re: Power supply input
March 24, 2014 05:42PM
Probably not. Do you have a link for the power supply? Does it have a voltage selector switch?
March 24, 2014 08:14PM
The power supply is from Ebay
The description on ebay says 90-264VAC but the label on the unit says 170-260VAC. I've requested the info from the supplier. I'll post the answer (if I ever get one).
March 25, 2014 12:06PM
It would have a selector switch on the side to toggle between 120v and 240v if it was compatible with both.
March 25, 2014 03:18PM
The Ebay vendor did reply and said that it will work with 110V supply. There are no selector switches. I am concerned about using such a cheap PS -- 400W for less than $10 -- but it's what I got in the kit so I'll try it.
March 26, 2014 11:46AM
Chances are you'll be fine since most use just a Live and Neutral line. They might have an L2 line or something but just ignore it.
