Today I will start my investigation into the fact that the Hictop Controllers are in fact a MKS BASE Shown Below.
This controller is a Ramps 1.4 Compatible controller but is a MKS Controller because it uses the Mosfet Pin 7 to power the 2nd extruder.
{pins_MKS_BASE.h}
// Power outputs EFBF or EFBE
#define MOSFET_D_PIN 7
If what I believe is in fact true then by changing Marlin from.
{Configuration.h}
#define MOTHERBOARD BOARD_RAMPS_14_EFB
//TO
#define MOTHERBOARD BOARD_MKS_13
This would indeed give me my 2nd extruder but this would also give me controls for a laser adapter
{pins_MKS_BASE.h}
// M3/M4/M5 - Spindle/Laser Control
#define SPINDLE_LASER_PWM_PIN 2 // MUST BE HARDWARE PWM
#define SPINDLE_LASER_ENABLE_PIN 15 // Pin should have a pullup!
#define SPINDLE_DIR_PIN 19
Asking for input from Hictop users if anyone knows for sure that I have come to the correct conclusion.
