sanguino port manipulation September 29, 2008 01:04PM |
Anonymous User
Re: sanguino port manipulation September 29, 2008 01:40PM |
Re: sanguino port manipulation September 29, 2008 09:42PM |
Anonymous User
Re: sanguino port manipulation September 30, 2008 10:59AM |
// ------------------------------------------------------------------------- // | Pin planner | // ------------------------------------------------------------------------- // * Top Edge * // ------------------------------|#|---------------------------------------- // |13 |12 |11 |10 |9 |8 |#|7 |6 |5 |4 |3 |2 |1 |0 | -- Pin ID // ------------------------------|#|---------------------------------------- // |13 |12 |PWM2|PMW1|PMW0|8 |#|7 |6 |5 |4 |3 |2 |TX |RX | -- Board Label // ------------------------------|#|---------------------------------------- // | | | | | | |#| | | | | | |TX |RX | -- Standard communications // | | | | | | |#| | | | |IN1 |IN0 | | | -- Interrupts // | | |AO2 |AO1 |AO0 | |#| | | | | | | | | -- Analogue outputs (Primary) // | | | | | | |#| |AO5 |AO4 | |AO3 | | | | -- Analogue outputs (Secondary) // |DI13|DI12|DI11|DI10|DI9 |DI8 |#|DI7 |DI6 |DI5 |DI4 |DI3 |DI2 |DI1 |DI0 | -- Digital Inputs // |DO13|DO12|DO11|DO10|DO9 |DO8 |#|DO7 |DO6 |DO5 |DO4 |DO3 |DO2 |DO1 |DO0 | -- Digital Outputs // |LED*| | | | | |#| | | | | | | | | -- Notes // ------------------------------|#|---------------------------------------- // |LED |DO12|DO11|AO1 |AO0 | |#| |DI6 |DI5 |DI4 |IN1 |IN0 |TX |RX | -- Chosen usage // ------------------------------|#|---------------------------------------- // // * Bottom Edge * // ------------------------------- // | Pin planner | // ------------------------------- // |14 |15 |16 |17 |18 |19 | -- Pin ID (Digital usage) // |0 |1 |2 |3 |4 |5 | -- Pin ID (Analog read usage) // ------------------------------- // |AI0 |AI1 |AI2 |AI3 |AI4 |AI5 | -- Board Label // ------------------------------- // |AI0 |AI1 |AI2 |AI3 |AI4 |AI5 | -- Analogue inputs // | | | | |SDA |SCL | -- I2C Inter board communications // |DI14|DI15|DI16|DI17|DI18|DI19| -- Digital Inputs // |DO14|DO15|DO16|DO17|DO18|DO19| -- Digital Outputs // ------------------------------- // | | | | |SDA |SCL | -- Chosen usage // ------------------------------- // // * LED - Has built in LED on Diecimila
Re: sanguino port manipulation October 05, 2008 11:16AM |
Re: sanguino port manipulation October 22, 2008 10:09PM |
