Arduino CNC Shield V3.0 May 14, 2014 02:32PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 02:53PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 03:13PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 03:46PM |
Anyway, have fun
Re: Arduino CNC Shield V3.0 May 14, 2014 03:57PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 04:25PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 04:57PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 06:20PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 06:44PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 06:57PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 07:00PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 07:10PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 07:16PM |
DR1983
I currently assigned pin 12, as it should be correct. Would this be changed in Marlin to 4 in order to work?
Re: Arduino CNC Shield V3.0 May 14, 2014 07:17PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 07:22PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 07:32PM |
#if MOTHERBOARD == 99 #define KNOWN_BOARD 1 #ifndef __AVR_ATmega328P__ #error Oops! Make sure you have 'Arduino Duemilanove w/ ATMega328' selected from the 'Tools -> Boards' menu. #endif #define X_STEP_PIN 2 #define Y_STEP_PIN 3 #define Z_STEP_PIN 4 #define X_DIR_PIN 5 #define Y_DIR_PIN 6 #define Z_DIR_PIN 7 #define X_ENABLE_PIN 8 #define Y_ENABLE_PIN 8 #define Z_ENABLE_PIN -1 #define E0_ENABLE_PIN -1 #define X_MIN_PIN 9 // investigate whats the deal with the asterisk in the image there #define Y_MIN_PIN 10 #define Z_MIN_PIN 11 #define X_MAX_PIN -1 // max endstops are not used #define Y_MAX_PIN -1 #define Z_MAX_PIN -1 // following are proposals #define E0_STEP_PIN 12 // or other which you can wire it onboard #define E0_DIR_PIN 13 // or other which you can wire it onboard #define HEATER_0_PIN 0 // extruder (digital numbering) #define HEATER_BED_PIN 1 // bed (digital numbering) #define TEMP_0_PIN 4 // 4 is A4, this or other pin that has nothing attached to it MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! #define TEMP_BED_PIN 5 // 5 is A5, this or other pin that has nothing attached to it MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!This is what i think for now, at very least to test the compilation size this should suffice for being as close as possible. If you get it to compile to a workeable size then this can be further refined.
Re: Arduino CNC Shield V3.0 May 14, 2014 07:49PM |
#define TEMP_1_PIN -1 #define TEMP_2_PIN -1 #define LED_PIN -1 #define PS_ON_PIN -1 #define FAN_PIN -1The problem is that the compile size is 50522 bytes and it gave me "sketch too big". I did a few changes and i got to ~46.6k but there isnt much i would disable and does not seem like could get it lower. So you have your work cut out to chop the firmware down to a smaller size. I dont think it will work out with marlin, but you can certainly try. At this time i would say you should perhaps switch to teacup in which case the config file will be a little different.
Re: Arduino CNC Shield V3.0 May 14, 2014 07:53PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 08:14PM |
Since cant find the sources, then we can surely conclude that Arduino CNC Shield is obviously closed source. If the sources are available for public download, that is what open source is. If the files are not available, then its closed source. There is no middle ground with gerbers or pictures or schematics, these are not sources. Sources are the files of the program in which the design of the board was made, e.g. kicad in this case.
I dont want to be rude but i find this situation very funny
Re: Arduino CNC Shield V3.0 May 14, 2014 08:35PM |
Re: Arduino CNC Shield V3.0 May 14, 2014 09:33PM |
