New MKS SBASE Smoothieware-compatible board from China April 20, 2015 06:30AM |
Chris Hax
Managed to translate some more information from baidu.com:
Features:
1, using 32 of the 100M Cortex-M3 LPC 1768 main chip, performance dramatically.
2, support highly modular open source firmware Smoothieware, convenient secondary development, eliminating worries can not grasp the core code.
3, support network function, you can directly access via cable network, using IE browser remote control.
4, using 8825 as a motor drive, supports 32 segments, performance than 4988, using SOP package, better heat dissipation.
5, stepper motor current set directly, without having to worry about damage to the drive or potentiometer to adjust the current time.
6, the circuit board with high-quality 4-layer, and made a special cooling optimization.
7, using a dedicated power chip, support 12V-24V power input.
8, can be connected to create customer base developed 12864LCD Dashboard MKS 12864.
9, can be connected to create customer base development touchscreen MKS TFT28.
Not real happy about the 8825's and it appears to use a single jumper to set stepping for all 5 drivers so if you decide to run 1/32 it would include the extruder steppers. On the plus side it uses a 4 layer board, digital pots and might support Reprapdiscount Ramps based LCD/adapter directly as well as their own "MKS" LCD.
Re: New MKS SBASE Smoothieware-compatible board from China June 07, 2015 05:12AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 07, 2015 05:17PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 07, 2015 09:42PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 13, 2015 09:13AM |
No offense but I have been on the net since 1996 and I have seen it all so when I see a brand new poster registered on the same day as the post they made with recommendations [edit: and a link to the product they say they purchased] I am a tad leary. It may be the best thing since pre sliced bread but we need more posters, who are well established, to chime in. Again, no offense but there are a lot of unscrupulous people, and sellers, who do these things so I am just saying.Quote
SUDO1
hi
i have bought this one
[www.ebay.com]
Shipped with Registered Post and took 10 to the US. USPS Premium / wow! And very well packed!
including a free 1G micro SD card with pre installed Smoothieware firmware and config.txt and 1 USB cable
very nicely made board, 100% new and works great on my reprap with Optic endstops
I will buy another one for my Delta build.
I can recommend it
Re: New MKS SBASE Smoothieware-compatible board from China June 16, 2015 09:01AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 16, 2015 10:34AM |
Let us know and what would be fantastic is for someone who gets one and breaks it out for people. The originator doesn't so forcibly do it for them for better or worse.Quote
CapnBry
I've been looking at electronics for my new printer and came across this as well. It has everything you need for dual extruders... unless you need always-on fans on your extruders like an E3D V6. Compared to the smoothieboard which has 3 large MOSFET outputs and 3 small MOSFET outputs, this has what looks like one largeish and 3 mediums. No specs so you can't tell exactly how large they are. Also, none of the pins they have in the breakout headers (EXP1 and EXP2) are hardware PWM pins. It would have been nice to have at least one, like 1.23.
Still, I am going to order one and put it through the paces on the benchtop with the FLIR camera to check out the heat dissipation and see how it goes. You just can't argue with that price, unless you're realistic and consider that for 1/3rd the cost of a smoothieboard, you're going to get what you pay for.
Re: New MKS SBASE Smoothieware-compatible board from China June 17, 2015 04:43PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 08:47AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 09:47AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 11:16AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 11:38AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 11:53AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 12:17PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 12:25PM |
Well, Boro glass is far from an insulator but I know what you mean. After much reading about this we use glass for only one reason and that is nothing else is as flat for cheap. MK heated plates are horrible with a bow or a bulge and the aluminum plate (my heat spreader) is far from flat as well so we use the glass which is flat. Even flatter is a mirror but it can't handle fast heatup and cool downs like Pyrex (Boro) glass can.Quote
the_digital_dentist
Even if the glass plate is flat and remains that way, flexing the "heat spreader" underneath means parts of the heat spreader won't be in contact with the glass. That's going to cause wide temperature variations over the surface of the glass and again, you'll have problems getting prints to stick. I've never understood the point of putting a thermal insulator on top of the bed plate. Why not just use a flat piece of aluminum and be done with it? Cast aluminum tooling plate works well. If you have to have a piece that comes off the bed with the print, start with a flat aluminum plate underneath and print on a thin piece of aluminum that clamps to the bed plate.
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 01:20PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 01:51PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 02:00PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 02:04PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 02:06PM |
Yeah, I already had the Boro or I would have used float glass from Lowes.Quote
dc42
There are at least two more reasons why many of us use glass beds, apart from its flatness:
1. It is cheap to replace if it gets scratched or otherwise damaged. No need to use borosilicate, ordinary float glass is entirely adequate if you have a heat spreader under it - and some people use float glass even without a heat spreader.
2. If the print sticks too well to the bed, you can remove the bed and put it in the fridge or freezer to release it. Meanwhile you can substitute another glass bed and get on with the next print.
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 03:45PM |
Dark Alchemist
I looked up the specs of flatness on Mic-6 from Alcoa (I did this last year but forgot) and they suck.
"Flatness tolerance is maintained within .015" on 1/4"-5/8" thickness and .005" on 3/4"- 4" thickness. Thermal Cycling can be performed up to 800° F under controlled conditions."
.015in is horrible and .005in is a lot better but the weight for a moving bed it would be way too heavy at 3/4in. .015in is 0.381mm which is larger than my first layer height can go (.28mm is my max) and .005in is .127mm so much better but, from what I understand, Boro, Float, Mirror, is much better flatness than those figures.
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 04:08PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 04:10PM |
I agree and another reason when I make my next printer it MUST have a non movable bed. With a non movable bed you have so much more freedom.Quote
dc42
Dark Alchemist
Weight of the bed isn't much of an issue with a non-moving bed, as on a delta printer. My latest delta uses 300mm diameter 5mm thick aluminium, with 4mm removable float glass on top. I was lucky because the aluminium plate was already flat enough to maintain good enough thermal contact with the glass.
All I can go by are those specs they publish.Quote
the_digital_dentist
The actual flatness you get is much better than the spec. I suspect that that spec is based on much larger sheets than are used in 3D printers. I put a steel ruler edge on my 1/4" plate and see very little deviation anywhere on its surface- by that I mean 10s of microns. I can't fit a sheet of paper between the ruler and the bed anywhere. I can print almost edge to edge.
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 04:31PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 10:13PM |
Yup, I got a 12x12x1/4" piece of cast MIC-6 aluminum for my bed for this new printer. Just like Dark Alchemist my i3 had a 4 point leveling mechanism. I could not get it level even using a servo z-endstop doing a 100 point calibration (this was before bed-leveling was in Marlin). It always would bow even if it was level. Then I replaced it with a cheap heated aluminum bed (china!). It came with a giant bow in it and was garbage. I then bought an official Mk3-ALU aluminum heat bed. It is reasonably flat but not completely, I ended up covering it with a borosillicate 3mm sheet and it was pretty good, I got about 75% of the build surface usable. Finally I drilled a new hole in my Y carriage and switched to a 3 point axis and it was the best it had ever been. Only took me a year and lots of money to get here.Quote
the_digital_dentist
Glass is definitely an insulator compared to aluminum.
My 12" x 12.5" x 1/4" cast/milled aluminum tooling plate cost $30 from an industrial metals supply company.
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 10:24PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 10:39PM |
dc42
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 11:09PM |
See, this is where I originally was ticked at Prusa's design of the Z carriage but I understand why he did it. For the i3 when the nozzle hits the bed, mine has done this hard and soft many many many times, the nozzle can't go any lower and eventually the M5 nuts go lower than the nut holder and nothing moves from then on except for a spinning M5. For a really stable printer that is beyond acceptable but, at least in my case, it saved my ass many a time.Quote
the_digital_dentist
I use 5 mil x 2" Kapton tape (http://www.amazon.com/Mil-Kapton-Tape-Polyimide-yds/dp/B0076DYH9Y/ref=sr_1_25?ie=UTF8&qid=1434679210&sr=8-25&keywords=5+mil+kapton) on my bed. It is a lot tougher than the typical 1 or 2 mil stuff people use and lasts for months until I eventually gouge it or tear it while removing a print. Then I just replace the strip(s) that is damaged. Yes, it leaves fine lines where the strips meet on the bottom of the print but they are of no consequence.
I have had the extruder crash into the plate on one or two occasions and it gouged through the tape and marred the aluminum (it would have broken a piece of glass). I just removed the tape and ran an abrasive metal "eraser" over the gouged area then replaced the tape. You can see the damaged area looking at the bed but it doesn't leave any marks on the prints.
Question, but if I sandwiched a MK2B in between two aluminum flat plates what would happen? The 1.6mm MK2B would be flat against the top plate for sure but when it heats up then what?Quote
the_digital_dentist
dc42
Have you considered using a thin aluminum piece covered with Kapton clamped to a tooling plate bed? You'd probably get more uniform temperature and still have the ability to throw it in the freezer if your printing schedule requires immediate restart of the machine. I would expect a piece of aluminum would shrink more than a piece of glass when you chill it, so it might pop off the print at least as well glass. Maybe it wouldn't stay flat when heated...
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 11:38PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2015 11:45PM |
Makes it flat so all of the heating side touches all of the top plate.Quote
the_digital_dentist
I don't understand the question. Why would you sandwich it between two aluminum plates? You're only going to print on the top. Aside from increasing the mass, what would adding a plate to the underside do?
