Controller and display recommendations please
Posted by jspring111
December 22, 2021 03:43PM
I want to put a new controller board in my core XY printer. It had a Rambo but that burned up. It has a Viki 2.0 display that has a specific enclosure so if i replaced it it would have to be replaced with something the same dimensions or smaller. 0 I was looking at the BTT boards but I can't figure out which ones I can use. I'd like to use the SKR Mini v3.0 because of the 3 controllable fan outputs but I don't know if that display will work. Can you recommend a suitable 32 bit board that would work with the Viki 2?
the Viki 2 plugs into the Rambo via a "RAMBo 1.3L->ROSi2.0 LCD Adapter Board Rev A". I looked around and all I could find is a Chris Riley video of a wifi adapter for the Viki and Reprap LCD where he plugs it into the EXP1 and EXP2 plugs on a SKR v1.3.
What I think I know is lcds plug into controller boards using either a TFT plug or these EXP1 and EXP2 plugs. I don't understand the communications protocol each of those use.
Any help would be much appreciated.
Thanks, Jim
