Re: CNC milling/router DIY build WIP August 08, 2017 03:54AM |
Re: CNC milling/router DIY build WIP August 09, 2017 03:43AM |
Re: CNC milling/router DIY build WIP August 09, 2017 04:12AM |
Re: CNC milling/router DIY build WIP August 15, 2017 05:12AM |
Re: CNC milling/router DIY build WIP August 18, 2017 08:10AM |
Re: CNC milling/router DIY build WIP August 20, 2017 01:49AM |
Re: CNC milling/router DIY build WIP August 20, 2017 11:57AM |
Re: CNC milling/router DIY build WIP August 28, 2017 04:20AM |
Re: CNC milling/router DIY build WIP August 31, 2017 06:54AM |
Re: CNC milling/router DIY build WIP September 01, 2017 09:37AM |
Re: CNC milling/router DIY build WIP September 02, 2017 09:44AM |
Re: CNC milling/router DIY build WIP September 06, 2017 09:38AM |
Re: CNC milling/router DIY build WIP September 07, 2017 06:19AM |
Re: CNC milling/router DIY build WIP September 07, 2017 11:58AM |
Re: CNC milling/router DIY build WIP September 08, 2017 12:20AM |
o_lampe
Wow, this PSU looks huge. The capacitors will be a challenge to switch on.
Is there a precharge circuit planned?
Re: CNC milling/router DIY build WIP September 08, 2017 02:56AM |
Re: CNC milling/router DIY build WIP September 08, 2017 07:57AM |
o_lampe
You can get away without precharge circuit, but don't be cheap on the on/off switch then.
Re: CNC milling/router DIY build WIP September 09, 2017 07:21AM |
Re: CNC milling/router DIY build WIP September 10, 2017 07:37AM |
Re: CNC milling/router DIY build WIP September 13, 2017 10:01AM |
Re: CNC milling/router DIY build WIP September 14, 2017 01:31AM |
Re: CNC milling/router DIY build WIP September 14, 2017 06:55AM |
o_lampe
I guess you can use :
M83 ;relative moves G92 X0 ; set X axis to zero G1 X1000 F1500 ; move 1000mm relative from there (-1000 to reverse direction )
Re: CNC milling/router DIY build WIP September 14, 2017 11:34AM |
Re: CNC milling/router DIY build WIP September 14, 2017 03:36PM |
Re: CNC milling/router DIY build WIP September 15, 2017 10:51AM |
Re: CNC milling/router DIY build WIP September 16, 2017 12:02PM |
Re: CNC milling/router DIY build WIP September 16, 2017 07:25PM |
Re: CNC milling/router DIY build WIP September 21, 2017 11:10AM |
Re: CNC milling/router DIY build WIP September 29, 2017 05:15AM |
Re: CNC milling/router DIY build WIP October 02, 2017 11:36PM |
