Re: Information needed before buying what I need December 27, 2014 08:55AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Information needed before buying what I need December 27, 2014 10:35AM |
Re: Information needed before buying what I need December 27, 2014 11:19AM |
Admin Registered: 19 years ago Posts: 14,205 |
Re: Information needed before buying what I need December 27, 2014 12:15PM |
VDX
... my experience with 'needed power to cut' is roughly: - 2x power = 4x cutting depth.
Check the needed current to switch the module - I'm driving all my modules with TTL-level (5V) and only some Mikro- to Milliamperes switching current, so any I/O-port can handle this ...
Analoge Modulation bedeutet, dass man mit einer Spannung welche sich zwischen 0 – 5V bewegt, die Laserdiode
zwischen 0 – 100% ihrer Leistung einstellen kann.
Wenn man also zum Beispiel 2.5V an den Modulationseingang anlegt, läuft die Laserdiode mit 50 % Ihrer Leistung.
Re: Information needed before buying what I need December 27, 2014 01:35PM |
Re: Information needed before buying what I need December 27, 2014 01:53PM |
Re: Information needed before buying what I need December 27, 2014 02:29PM |
MPower
Definitely not percent/10 as it goes to 12. The column is probably that "O.D.", whatever OD means
Later edit: oh yeah, optical density.
[www.lia.org]
so you are fine with 5 at 445nm using around 1W.
Re: Information needed before buying what I need December 27, 2014 07:13PM |
Re: Information needed before buying what I need December 27, 2014 08:22PM |
Re: Information needed before buying what I need December 28, 2014 02:10PM |
Re: Information needed before buying what I need December 28, 2014 05:19PM |
Re: Information needed before buying what I need December 28, 2014 06:08PM |
Re: Information needed before buying what I need December 28, 2014 06:37PM |
Re: Information needed before buying what I need December 29, 2014 02:56AM |
Re: Information needed before buying what I need December 29, 2014 06:26AM |
I like to learn to make, not to learn how to use a machine that's already put together.
Re: Information needed before buying what I need December 29, 2014 06:49AM |
Re: Information needed before buying what I need December 29, 2014 12:50PM |
MPower
Yes, there is always the DIY factor. And pre-owning a 3D printer already gets you the positioning system ready. However, I find the prices for diodes kinda ridiculous. To be more specific, you would expect that at the technology state of 2014-2015 a tiny 2W diode would cost way less then 300 EURO. That also applies for the driver - after you receive it, try to look up the costs for the components on your favorite electronic components supplier and add a few cents for the tiny PCB. The highest gain I see with diodes would be etching PCBs, diodes having a much finer dot.
Re: Information needed before buying what I need December 29, 2014 03:54PM |
Re: Information needed before buying what I need December 29, 2014 04:31PM |
analogWrite(SomePin, Voltage * 255 / 5);if you want to set it by voltage value, or
analogWrite(SomePin, Percent * 255 / 100);if you want to set it by power percent value, considering 5V (255 full duty cycle) as 100% power.
Re: Information needed before buying what I need December 29, 2014 07:55PM |
Re: Information needed before buying what I need December 29, 2014 09:09PM |
Re: Information needed before buying what I need December 30, 2014 07:06AM |
Re: Information needed before buying what I need December 30, 2014 02:10PM |
Re: Information needed before buying what I need December 30, 2014 10:55PM |
Re: Information needed before buying what I need January 01, 2015 07:18PM |
Re: Information needed before buying what I need January 02, 2015 06:43PM |
Re: Information needed before buying what I need January 03, 2015 07:31PM |
Re: Information needed before buying what I need January 03, 2015 08:07PM |
(Dutch expression)|
Re: Information needed before buying what I need January 03, 2015 09:35PM |
Re: Information needed before buying what I need January 04, 2015 05:35AM |
The CoreXY setup is almost finished too! Cutting area will be 220x280mm. This is expandable if I buy longer rods and longer aluminium extrusions. Sizing it up is a simple process with the machine I've built now. The only thing I should do when I make it bigger, is to go to 10 or 12 mm chromed rods instead of the 8mm I use now. Deflection right now is unnoticeable but will be an issue if sized up.
