Laser 5.5watt Connecting issue December 14, 2018 12:43PM |
Re: Laser 5.5watt Connecting issue December 14, 2018 05:34PM |
Re: Laser 5.5watt Connecting issue December 14, 2018 05:46PM |
cozmicray
The TTL trigger is not a voltage dependent control.
The trigger pins normally are pulse width modulated (PWM) to control laser output
More time ON ( at 5V) the greater the laser ON - more power.
So you have to set up your control pin to PWM
or select a pin that can set PWM frequency
Read
[reprap.org]
Re: Laser 5.5watt Connecting issue December 15, 2018 08:18AM |
Re: Laser 5.5watt Connecting issue December 15, 2018 06:12PM |
Re: Laser 5.5watt Connecting issue December 15, 2018 07:01PM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Laser 5.5watt Connecting issue December 15, 2018 07:34PM |
Re: Laser 5.5watt Connecting issue December 15, 2018 07:50PM |
Re: Laser 5.5watt Connecting issue December 15, 2018 07:53PM |
Re: Laser 5.5watt Connecting issue December 16, 2018 05:53AM |
Re: Laser 5.5watt Connecting issue December 16, 2018 09:01AM |
Re: Laser 5.5watt Connecting issue December 16, 2018 10:46AM |
Re: Laser 5.5watt Connecting issue December 16, 2018 11:57AM |
Re: Laser 5.5watt Connecting issue December 16, 2018 12:09PM |
Re: Laser 5.5watt Connecting issue December 16, 2018 05:29PM |
Re: Laser 5.5watt Connecting issue December 16, 2018 07:58PM |
Re: Laser 5.5watt Connecting issue December 16, 2018 07:59PM |
Re: Laser 5.5watt Connecting issue December 16, 2018 08:47PM |
Re: Laser 5.5watt Connecting issue December 16, 2018 10:14PM |
