Laser Engraver: ArduinoMega2560+Ramps1.4+drv8825 January 24, 2019 12:43PM |
Re: Laser Engraver: ArduinoMega2560+Ramps1.4+drv8825 January 24, 2019 01:30PM |
Re: Laser Engraver: ArduinoMega2560+Ramps1.4+drv8825 January 24, 2019 08:54PM |
Re: Laser Engraver: ArduinoMega2560+Ramps1.4+drv8825 January 25, 2019 01:34PM |
frankvdh
The +12 & GND on the laser are connected to the power supply.
It looks like this software is for a CNC machine with a motor-driven spindle. I guess you could use the motor on/off signal to turn your laser on/off, in which case you would connect the laser ttl+ to D10 and the the ttl1 to GND.
What wattage laser did you buy? Please post back how well it works.
Re: Laser Engraver: ArduinoMega2560+Ramps1.4+drv8825 January 27, 2019 04:29PM |
Re: Laser Engraver: ArduinoMega2560+Ramps1.4+drv8825 January 28, 2019 12:28AM |
cozmicray
Laser should be connected to 12V supply
from DZT 's Store website ---- PWM/TTL:support . TTL 0v off ,5v on
so supplying 5V to the TTL should trigger (turn ON) the laser
The TTL is modulated by a PWM signal from controller to get various power output
(longer pulse width --- more laser ON time)
What firmware and software are you using?
Many of SW programs allow selection of how laser is triggered.
Re: Laser Engraver: ArduinoMega2560+Ramps1.4+drv8825 January 30, 2019 08:04PM |
