Kapton tape heated bed August 25, 2021 03:49PM |
Re: Kapton tape heated bed August 25, 2021 05:38PM |
Re: Kapton tape heated bed August 26, 2021 08:59AM |
Re: Kapton tape heated bed August 26, 2021 09:38AM |
Re: Kapton tape heated bed August 26, 2021 10:20AM |
Re: Kapton tape heated bed August 26, 2021 01:41PM |
Re: Kapton tape heated bed August 26, 2021 01:47PM |
Re: Kapton tape heated bed August 26, 2021 02:44PM |
Re: Kapton tape heated bed August 27, 2021 10:03AM |
Re: Kapton tape heated bed August 27, 2021 04:32PM |
Re: Kapton tape heated bed August 28, 2021 10:56PM |
Re: Kapton tape heated bed August 29, 2021 05:21AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Kapton tape heated bed August 29, 2021 07:06AM |
Re: Kapton tape heated bed August 29, 2021 02:15PM |
Re: Kapton tape heated bed August 29, 2021 02:38PM |
Re: Kapton tape heated bed August 29, 2021 03:22PM |
Re: Kapton tape heated bed August 29, 2021 06:45PM |
pmd10
In that case I'll most probably use a 5mm thick aluminium plate as you say and I'll see what I can do about the steel plate.
Thanks a lot for you time
Re: Kapton tape heated bed August 29, 2021 06:53PM |
pmd10
Thanks for all the responses but there is still one thing I don’t get.
As Mike said at the beginning, 300x300 beds will need between 270-540W of power. Then Petters’ video ( very helpful by the way ) showed that some beds can even use 700W. And, apart from that, he has bought a 1400W heater.
Now, my question is, what is the point of all this power if most motherboards can’t even get to it? To set an example none of the bightreetech 6 motors motherboards ( the octopus ( 300W) and the skr pro ( 360W )) can?
Apart from that, how would a, let's say 360+W, bed perform with any of the previous motherboards?
Re: Kapton tape heated bed August 29, 2021 06:59PM |
VDX
... if you're new to 3D-printing, then better start with 300x300mm max -- bigger brings a lot more problems! ... even 300x300mm is not so easy - many experienced DIY-ers resigned with bigger volumes for heating and warping issues ...
Re: Kapton tape heated bed August 29, 2021 07:14PM |
pmd10
The thing is that my design requires five magnets (3mm thick) (I want to avoid using a magnetic surface to make the heat transmission as efficient as possible) to hold the flexible steel platform. However, the aluminium base that I’m using is 3mm thick and I don’t want it to be any thicker because of the weight. Those magnets will be embeded into the base and in order to prevent them from falling I’m going to install “mounts”. That is why the heating pad has 5 rectangular holes. Don’t know if there is any other way to do it…
Apart from that, are there going to be any changes if I use an AC power supply rather than a DC one apart from the cost and safety aspects? (I might change to an AC one after what you’ve told me)
Re: Kapton tape heated bed August 29, 2021 08:39PM |
the_digital_dentist
A heater doesn't care if it's powered by DC or AC, so why spend extra money on a big power supply to give it tightly regulated DC? Switching power to a DC heater requires a DC SSR and they tend to get hot in operation, so you have to cool them, usually with a heatsink (cost) and fan (noise). Line power switching using an AC SSR leaves the SSR as cool as a cucumber without a fan, and often without a heatsink. Low voltage DC power requires a heavier cable- its lack of flexibility can be a problem depending on the printer architecture.
I suspect that variations in the thickness/width of the copper tape will result in hot spots that may burn through the conductor or just make for uneven heating. You can buy 300mm square heaters from competent manufacturers in China for about $70-80. How many hours, generations of prototypes, and how much material cost are you going to need to develop your own heater? Some things (like designing and building a 3D printer) are worth DIY because you learn a lot of useful stuff even if there are commercial alternatives readily and cheaply available. Designing and building a bed heater doesn't seem like one of those things. The heater should be the size of the bed plate- leaving an unheated rim around the plate will lead to warping when it's heated.
Not sure how much power you need for the bed heater? This calculator will tell you how long you'll be waiting for the bed to reach target temperature based on heater power and bed plate material and size.
I don't know what you're planning to use for the bed plate, but you might want to consider a kinematic mount that uses 3 support points instead of putting "leveling" screws at 4 corners (and the center?) of the plate. The hole at the center of the heater will create a cool spot there, right where slicers are going to put the print. If you use the right bed plate (cast aluminum) on a kinematic mount, you won't have to relevel the bed after initial set-up. You won't need auto leveling or flatness compensation, considerably simplifying the electronics, configuration, and Z axis mechanism and reducing the cost of the printer. It will be easier to troubleshoot and maintain the printer, too.
Those so-called "LED strip" power supplies are unreliable junk. Spend a few $ more and get a MeanWell supply that has safety certifications and built-in protective circuits that actually work. Buy a power supply that is rated for at least 30-50% more power than the printer will actually need. Don't operate anything, especially power supplies, at their capacity limits. It's a recipe for disaster.
Re: Kapton tape heated bed August 30, 2021 01:28AM |
Re: Kapton tape heated bed August 30, 2021 02:30AM |
pmd10
I don’t know if by telling you the thickness of the tape (0,06mm) you would be able to tell me if that is the right one to go with or if I should try buying a different one.
And apart from that, from what I’ve understood it would be better to buy a 520W+ power supply rather than using the one I currently have. Am I right?
Re: Kapton tape heated bed August 30, 2021 02:40AM |
Re: Kapton tape heated bed August 30, 2021 02:52AM |
Re: Kapton tape heated bed August 30, 2021 03:25AM |
Re: Kapton tape heated bed August 30, 2021 06:21AM |
OldBikerPete
...................You shouldn't have a problem with the different expansion of your steel bed and aluminium plate as your magnetic fixing method will allow the two to slide against each other..........
OldBikerPete
..................Can you tell me if insulating the underside of the bed is commonly done? What material do you use the insulate under yours?.................
OldBikerPete
.................a 3d printer doesn't put any transverse force on a print so one can get away with doing this
Re: Kapton tape heated bed August 30, 2021 07:15PM |
I've settled on a Schneider Electric 6210SZS-DC3 zero-crossing type SSR. I've attached a link to the data sheet and a capture of a retailer's listing. Note that a significant heat sink is recommended. The entire base of my printer will be a custom aluminium box, so I will bolt the relay to that.Quote
leadinglights
To get to higher powers a solid-state relay would be used for DC and either a solid-state relay or an SCR with a zero-crossing driver for an AC circuit. I can't recommend any particular one but I am sure I have seen such recommendations on this forum in the past.
Mike
Re: Kapton tape heated bed May 19, 2023 09:23AM |
