Re: Designing a reliable and accurate Z axis. June 04, 2015 12:43PM |
Re: Designing a reliable and accurate Z axis. June 04, 2015 12:47PM |
Re: Designing a reliable and accurate Z axis. June 04, 2015 12:53PM |
FalloutBe
Thanks again cozmicray, for all your help (;
I'm going for the cantilevered platform, 4 bearings, 2 smooth rods and a single lead screw.
What do you think will be best?
[www.ebay.com] (delrin nut)
or
[www.ebay.com] (motor attached, regular nut)
or
[www.ebay.com] (motor attached, regular nut, coupler)
The delrin nut states to have much better resolution, and it is cheaper.
The regular lead screws all seem to have an 8mm pitch, which I think is too large.
Anti backlash nuts or regular nuts?
The sets on ebay don't have anti backlash nuts :/ Do you think it is necessary?
Gravity should keep it down, but my platform is moving downwards along the print, so it might stick.
EDIT: I want at least 20micron layers!
Re: Designing a reliable and accurate Z axis. June 04, 2015 12:58PM |
Re: Designing a reliable and accurate Z axis. June 04, 2015 01:57PM |
Re: Designing a reliable and accurate Z axis. June 04, 2015 02:44PM |
Re: Designing a reliable and accurate Z axis. June 04, 2015 02:59PM |
Re: Designing a reliable and accurate Z axis. June 04, 2015 03:12PM |
FalloutBe
If I can however create a perfect Z axis, let's say 20(+-0.1) microns, you almost wouldn't notice that the part was 3d printed!
Re: Designing a reliable and accurate Z axis. June 04, 2015 03:21PM |
Re: Designing a reliable and accurate Z axis. June 04, 2015 03:52PM |
FalloutBe
Hmm well yes, the Z precision of my XY axis will probably be worse than the Z axis.
But right now I have a terrible Z axis, and I just want to get it as good as I possibly can.
I don't care if my XY axis becomes the worst factor in play. At least I will be happy with my Z axis then.
I attached a picture of what I have in mind right now. What do you think?
It is a 1204 ballscrew
Re: Designing a reliable and accurate Z axis. June 04, 2015 04:59PM |
Re: Designing a reliable and accurate Z axis. June 04, 2015 09:20PM |
Re: Designing a reliable and accurate Z axis. June 05, 2015 12:55AM |
Re: Designing a reliable and accurate Z axis. June 10, 2015 03:50AM |
In the case of three threaded rods and one motor, do you think that an autobedleveling use with inductive sensor can solve the problem of synchronization?Quote
dc42
FalloutBe
"The one that doesn't move"
Haha, indeed (;
But Something has to move in the Z direction.
This is the big advantage of delta printers: the bed and the print don't move. The head moves in all 3 dimensions; but it is much lighter than the bed, assuming you use a Bowden extruder, and therefore easier to move.
FalloutBe
I'm quite stuck now with the idea of "really wanting the bed to be my Z axis" because I am really happy with how well the XY assembly performs.
There are at least the following ways of moving the bed in the Z direction:
1. Single leadscrew or threaded rod, and linear bearings. May be the best solution for small beds.
2. Multiple (typically 3 or 4) leadscrews driven from a single stepper motor via belts.
3. Multiple stepper motors driving leadscrews to support the bed, driven in series or in parallel. Problem is sync the motors when you turn the printer on.
4. Three stepper motors driving leadscrews, driven independently by the electronics. The firmware can use a Z probe to probe at least 3 points during Z homing, and adjust the 3 motors to get the bed level. I think this may be the best approach for really large beds. But it needs another 2 stepper motor drivers.
Re: Designing a reliable and accurate Z axis. June 10, 2015 06:19AM |
mdcompositi
Re: Designing a reliable and accurate Z axis. June 10, 2015 06:28AM |
I have 250x300 bed, when I calibrate it with the four springs in the corners, I start a print and all work well!Quote
dc42
mdcompositi
With three threaded rods driven from one motor by a belt, once you have set up the system you shouldn't get any synchronization problems.
btw there are other reliable height sensors besides inductive, for example the differential IR ones I list here [forums.reprap.org] are designed to work well on glass.
Re: Designing a reliable and accurate Z axis. June 10, 2015 07:25AM |
mdcompositi
Re: Designing a reliable and accurate Z axis. June 10, 2015 07:28AM |
the_digital_dentist
The other problem- nonorthogonal axes- may let your print finish but it will be poor quality, so it too, is a disaster (for printing anything but Yoda heads and tugboats) because it wastes time and material.
Re: Designing a reliable and accurate Z axis. June 10, 2015 07:44AM |
mdcompositi
the next print, or when z axis move simply, need a new little calibration!
belt is tensioned ad all work good!!
what do you think about?
Re: Designing a reliable and accurate Z axis. June 10, 2015 08:13AM |
Re: Designing a reliable and accurate Z axis. June 10, 2015 08:34AM |
as I said before, I have three screws and not fourQuote
the_digital_dentist
mdcompositi
Auto-tramming does absolutely nothing for syncing the screws. All it does is level the bed so the first layer will stick. It relies on three assumptions: that the screws will remain in sync after auto leveling is done, and that the axes of the printer are orthogonal, and that the bed is a flat plane. Losing sync is a disaster and guarantees your print will fail. Using threaded rods instead of lead screws is asking for problems, as is using four screws instead of three. Threaded rods are not straight. One motor will bind and slip. When that happens with four screws, the whole mechanism will bind. With two or three screws, the print may continue for a while (with a tilted bed) or the bed may bind and stop moving. You'll probably have to manually adjust the screws before you can get the thing to home the bed again.
Using four screws to level the bed or lift it in the Z axis almost guarantees the bed won't be flat.
Re: Designing a reliable and accurate Z axis. June 10, 2015 08:40AM |
Re: Designing a reliable and accurate Z axis. June 10, 2015 08:54AM |
Re: Designing a reliable and accurate Z axis. June 10, 2015 05:28PM |
Re: Designing a reliable and accurate Z axis. June 11, 2015 07:06AM |
Re: Designing a reliable and accurate Z axis. July 04, 2015 12:09PM |
