threaded rod steps. April 15, 2017 06:32AM |
Re: threaded rod steps. April 15, 2017 09:22AM |
Re: threaded rod steps. April 15, 2017 09:13PM |
Um, 360 degrees/200 steps = 1.8 degree/step but otherwise correct.Quote
Srek
M8 thread has 1.25mm/1. If you have a standard 1.6° 200 steps/1 stepper motor 1mm will take 160 full steps These 160 full steps need to be multiplied by whatever microstepping you use, if it is 32 you get 5120 steps/mm.
Re: threaded rod steps. April 16, 2017 12:53PM |
Re: threaded rod steps. April 16, 2017 01:07PM |
Re: threaded rod steps. April 16, 2017 02:44PM |
Bugger, it felt off, but i did not see the error. Thanks for the correction.Quote
seattle_phil
Srek
Re: threaded rod steps. April 20, 2017 12:51PM |
