I have designed an application-specific, zero-backlash gears system. RFC ... April 20, 2017 01:20PM |
Re: Can you guys confirm if this is zero-backlash? April 20, 2017 02:59PM |
Re: Can you guys confirm if this is zero-backlash? April 20, 2017 03:07PM |
Re: Can you guys confirm if this is zero-backlash? April 20, 2017 03:22PM |
Re: Can you guys confirm if this is zero-backlash? April 20, 2017 03:45PM |
Re: Can you guys confirm if this is zero-backlash? April 21, 2017 02:08AM |
Re: Can you guys confirm if this is zero-backlash? April 21, 2017 07:36AM |
Re: Can you guys confirm if this is zero-backlash? April 21, 2017 07:59AM |
Re: I have designed an application-specific, zero-backlash gears system. RFC ... April 21, 2017 12:27PM |
Re: Can you guys confirm if this is zero-backlash? April 21, 2017 12:30PM |
realthor
@DC: Ideally the tooth engagement is to have contact with both larger gear's adjacent tooth flanks or with several teeth but in practice the gears are not perfect and there is always a gap besides the tooth (pls excuse me if this looks like lecturing you, it's not):
However, because I am tensioning the cable (steel?) so that both driven gears press on opposing flanks on the motor gear's teeth (somehow preventing it to turn), even with the backlash, at each direction of rotation the motor gear will drive one of the gears with tooth-on-tooth contact and that driven gear, via the cable, will rotate the other gear accordingly, thus having no backlash at all (in theory):
Now, if all still looks good to you too, I was thinking of steel cable (can even be adapted for spectra I guess if this is to be used on a light CNC machine like a 3d printer). If the tension alone is not enough and it needs more elasticity I would add a spring along the cable but my idea is that tension in a non-elastic cable will be enough because, like I have explained above, the backlash will be a non-issue once the motor gear engages one of driven gears teeth and the driven gear is basically engaged by the cable pulling on it as opposed to the motor gear.
@powdermetal... I am afraid I don't quite get what you are saying. Could you elaborate a bit or explain so it gets through my skull
Re: I have designed an application-specific, zero-backlash gears system. RFC ... April 21, 2017 04:44PM |
, some room for error is needed for such situation and if the tension I put in the system is too much then the motor will skip steps and if it's too low the backlash will not have been rendered out of the system. So I believe that either the cable should be capable of minute elasticity while still providing quite strong tension to overcome backlash or a spring will be necessary.
