"Form Tapping" V-slot Extrusions August 04, 2020 03:04AM |
Re: "Form Tapping" V-slot Extrusions August 04, 2020 03:16AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: "Form Tapping" V-slot Extrusions August 04, 2020 03:33AM |
Re: "Form Tapping" V-slot Extrusions August 04, 2020 04:51AM |
Re: "Form Tapping" V-slot Extrusions August 04, 2020 07:35AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: "Form Tapping" V-slot Extrusions August 04, 2020 10:16AM |
Re: "Form Tapping" V-slot Extrusions August 04, 2020 06:17PM |
the_digital_dentist
Assembling the frame that way really only works if the end of the tapped piece is square. If not, you're going to need to use plates to hold the members square to each other. You will probably need to mill the ends to ensure squareness. I've been assembling frames that way from my first printer, but I have access to mills...
Re: "Form Tapping" V-slot Extrusions August 05, 2020 03:19AM |
Re: "Form Tapping" V-slot Extrusions August 05, 2020 11:48PM |
MKSA
The point here is to use an extrusion (thread forming) tap instead of a cutting tap ! They are of course not just to tap Al extruded profiles.
This method gives a stronger thread besides Al is a bitch to machine ! You are more likely to break a cutting tap in Al than in regular steel.
These taps are more expensive, the hole must be the correct size and of course it needs good lubrication.
Re: "Form Tapping" V-slot Extrusions August 06, 2020 06:39AM |
Re: "Form Tapping" V-slot Extrusions August 06, 2020 05:40PM |
the_digital_dentist
I don't think he type of tap you use means much other than the mechanical effort required to use the tap. If you get about 1 cm of threads in the hole for the screw to grip it will be fine and you won't be able to strip the hole by turning the screw with a hand tool.
If you're talking about tapping 2020 t-slot your joints will be tight and strong, but the t-slot will still be flexible as over cooked spaghetti.
Re: "Form Tapping" V-slot Extrusions August 06, 2020 11:40PM |
Re: "Form Tapping" V-slot Extrusions August 07, 2020 06:30AM |
