How to compile Marlin source code with arduino1.0.3 and Gen7 2.1? February 15, 2013 08:52AM |
In file included from cardreader.cpp:1: /Marlin.h:33:26: error: WProgram.h: No such file or directory In file included from /Marlin.h:41, from cardreader.cpp:1: MarlinSerial.h:119: error: expected ',' or '...' before '&' token MarlinSerial.h:119: error: ISO C++ forbids declaration of 'String' with no type MarlinSerial.h:138: error: expected ',' or '...' before '&' token MarlinSerial.h:138: error: ISO C++ forbids declaration of 'String' with no type /MarlinSerial.h: In member function 'void MarlinSerial::print(int)': MarlinSerial.h:121: error: 's' was not declared in this scope In file included from cardreader.cpp:1: /Marlin.h: In function 'void serialPrintFloat(float)': Marlin.h:115: error: call of overloaded 'print(int)' is ambiguous /MarlinSerial.h:119: note: candidates are: void MarlinSerial::print(int) /MarlinSerial.h:126: note: void MarlinSerial::print(const char*) /MarlinSerial.h:130: note: void MarlinSerial::print(char, int) /MarlinSerial.h:131: note: void MarlinSerial::print(unsigned char, int) /MarlinSerial.h:132: note: void MarlinSerial::print(int, int) /MarlinSerial.h:133: note: void MarlinSerial::print(unsigned int, int) /MarlinSerial.h:134: note: void MarlinSerial::print(long int, int) /MarlinSerial.h:135: note: void MarlinSerial::print(long unsigned int, int) /MarlinSerial.h:136: note: void MarlinSerial::print(double, int) Marlin.h:118: error: call of overloaded 'print(int)' is ambiguous /MarlinSerial.h:119: note: candidates are: void MarlinSerial::print(int) /MarlinSerial.h:126: note: void MarlinSerial::print(const char*) /MarlinSerial.h:130: note: void MarlinSerial::print(char, int) /MarlinSerial.h:131: note: void MarlinSerial::print(unsigned char, int) /MarlinSerial.h:132: note: void MarlinSerial::print(int, int) /MarlinSerial.h:133: note: void MarlinSerial::print(unsigned int, int) /MarlinSerial.h:134: note: void MarlinSerial::print(long int, int) /MarlinSerial.h:135: note: void MarlinSerial::print(long unsigned int, int) /MarlinSerial.h:136: note: void MarlinSerial::print(double, int) /Marlin.h: At global scope: Marlin.h:124: error: variable or field 'manage_inactivity' declared void Marlin.h:124: error: 'byte' was not declared in this scope cardreader.cpp: In constructor 'CardReader::CardReader()': cardreader.cpp:29: error: 'millis' was not declared in this scope cardreader.cpp: In member function 'void CardReader::checkautostart(bool)': cardreader.cpp:419: error: 'millis' was not declared in this scope cardreader.cpp: In member function 'void CardReader::fast_xfer(char*)': cardreader.cpp:538: error: 'boolean' was not declared in this scope cardreader.cpp:538: error: expected `;' before 'done' cardreader.cpp:541: error: 'LOW' was not declared in this scope cardreader.cpp:541: error: 'LOW' was not declared in this scope cardreader.cpp:542: error: 'LOW' was not declared in this scope cardreader.cpp:542: error: 'LOW' was not declared in this scope cardreader.cpp:586: error: 'done' was not declared in this scope
#For "old" Arduino Mega #MCU = atmega1280 #For Arduino Mega2560 #MCU = atmega2560 #For Sanguinololu #MCU = atmega644p MCU = atmega1284p #For Printrboard #MCU = at90usb1286 #Arduino install directory INSTALL_DIR = ../../arduino-1.0.3/ # Be sure to regenerate speed_lookuptable.h with create_speed_lookuptable.py # if you are setting this to something other than 16MHz F_CPU = 16000000 UPLOAD_RATE = 115200 AVRDUDE_PROGRAMMER = arduino PORT = /dev/arduino TARGET = $(notdir $(CURDIR)) ############################################################################ # Below here nothing should be changed... ARDUINO = $(INSTALL_DIR)/hardware/Gen7/arduino/cores/arduino AVR_TOOLS_PATH = SRC = $(ARDUINO)/pins_arduino.c $(ARDUINO)/wiring.c \ $(ARDUINO)/wiring_analog.c $(ARDUINO)/wiring_digital.c \ $(ARDUINO)/wiring_pulse.c \ $(ARDUINO)/wiring_shift.c $(ARDUINO)/WInterrupts.c CXXSRC = $(ARDUINO)/WMath.cpp $(ARDUINO)/WString.cpp\ $(ARDUINO)/Print.cpp applet/Marlin.cpp MarlinSerial.cpp Sd2Card.cpp SdBaseFile.cpp SdFatUtil.cpp SdFile.cpp SdVolume.cpp motion_control.cpp planner.cpp stepper.cpp temperature.cpp cardreader.cpp MatrixMath.cpp FPUTransform.cpp z_probe.cpp FORMAT = ihex
Re: How to compile Marlin source code with arduino1.0.3 and Gen7 2.1? February 16, 2013 07:26AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: How to compile Marlin source code with arduino1.0.3 and Gen7 2.1? March 26, 2013 03:19AM |
#if ARDUINO >= 100 #if defined(__AVR_ATmega644P__) || defined (__AVR_ATmega1284P__) #include "WProgram.h" #else #include "Arduino.h" #endif #else #include "WProgram.h" #endif
In file included from Marlin.ino:51: /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/variants/gen7/pins_arduino.h:50: error: redefinition of 'const uint8_t A0' WProgram.h:51: error: 'const uint8_t A0' previously defined here /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/variants/gen7/pins_arduino.h:51: error: redefinition of 'const uint8_t A1' WProgram.h:52: error: 'const uint8_t A1' previously defined here /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/variants/gen7/pins_arduino.h:52: error: redefinition of 'const uint8_t A2' WProgram.h:53: error: 'const uint8_t A2' previously defined here /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/variants/gen7/pins_arduino.h:53: error: redefinition of 'const uint8_t A3' WProgram.h:54: error: 'const uint8_t A3' previously defined here /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/variants/gen7/pins_arduino.h:54: error: redefinition of 'const uint8_t A4' WProgram.h:55: error: 'const uint8_t A4' previously defined here /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/variants/gen7/pins_arduino.h:55: error: redefinition of 'const uint8_t A5' WProgram.h:56: error: 'const uint8_t A5' previously defined here /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/variants/gen7/pins_arduino.h:56: error: redefinition of 'const uint8_t A6' WProgram.h:57: error: 'const uint8_t A6' previously defined here /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/variants/gen7/pins_arduino.h:57: error: redefinition of 'const uint8_t A7' WProgram.h:58: error: 'const uint8_t A7' previously defined here In file included from Marlin.ino:154: /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/cores/arduino/Arduino.h:207: error: default argument given for parameter 3 of 'long unsigned int pulseIn(uint8_t, uint8_t, long unsigned int)' /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/cores/arduino/Arduino.h:116: error: after previous specification in 'long unsigned int pulseIn(uint8_t, uint8_t, long unsigned int)' /Applications/Arduino.app/Contents/Resources/Java/hardware/Gen7/cores/arduino/Arduino.h:209: error: default argument given for parameter 3 of 'void tone(uint8_t, unsigned int, long unsigned int)' WProgram.h:24: error: after previous specification in 'void tone(uint8_t, unsigned int, long unsigned int)'
Re: How to compile Marlin source code with arduino1.0.3 and Gen7 2.1? April 05, 2013 12:58AM |
Re: How to compile Marlin source code with arduino1.0.3 and Gen7 2.1? April 05, 2013 07:07AM |
Re: How to compile Marlin source code with arduino1.0.3 and Gen7 2.1? April 07, 2013 11:02PM |
