Marlin and Sanguinololu
Posted by ricros
November 28, 2012 07:31PM
Hi
What do I need to configure in order to compile Marlin firmware for a Sanguinololu?
I've changed the motherboard type to 62 in the configuration.h file but I still have errors:
In file included from /Marlin.h:25,
                 from cardreader.cpp:1:
/pins.h:668:5: error: invalid suffix "z" on integer constant
/pins.h:757:5: error: invalid suffix "z" on integer constant
/pins.h:892:5: error: invalid suffix "z" on integer constant
/pins.h:963:5: error: invalid suffix "z" on integer constant
/pins.h:1022:5: error: invalid suffix "z" on integer constant
/pins.h:1104:5: error: invalid suffix "z" on integer constant
/pins.h:1161:5: error: invalid suffix "z" on integer constant
/pins.h:1230:5: error: invalid suffix "z" on integer constant
/pins.h:1305:5: error: invalid suffix "z" on integer constant
/pins.h:1405:2: error: #error Unknown MOTHERBOARD value in configuration.h
In file included from /Marlin.h:37,
/MarlinSerial.h:68:5: error: invalid suffix "z" on integer constant
In file included from cardreader.cpp:1:
/Marlin.h:48:5: error: invalid suffix "z" on integer constant
In file included from cardreader.cpp:6:
/language.h:23:5: error: invalid suffix "z" on integer constant
/language.h:23:25: error: invalid suffix "z" on integer constant
Do I need to change something else?
Thanks
Re: Marlin and Sanguinololu
November 29, 2012 10:00AM
I'm also having problems in Arduino 1.0 or 23 when I complile (verify) the latest Marlin 1.0 with any of the sanguino motherboards (62) selected, but my errors are different under Mac OS 10.6.8. It compiles fine when I select an AT Mega motherboard like 33 or 34. Is anyone here able to do this in the Mac?
December 19, 2012 02:24PM
Anyone?
December 19, 2012 03:29PM
Have you copied the Sanguino folder from Marlin to arduino hardware folder?
December 21, 2012 12:42PM
Yes, I did
April 30, 2013 11:40PM
have you had any luck getting this going?
