Hello reprap world! This is my first post as I am just at the calibration stage of my new printer.
I seem to have changed something in the firmware that broke the y coordinates. Its a custom Delta Style printer, running repetier firmware and repetier host. I am able to make manual moves from around -2mm to 70mm. My build area should have a radius of 150. It isn't a problem for the x axis. Its almost like there is a setting somewhere that is controlling my min and max y locations, but it being a delta style printer I can't figure out where it would.
I had it running well but when I went to calibrate it so it would print to correct scale I started having this issue. But I can't find what did it.
Thanks,
Deven
