Marlin Upload problem
Posted by Hypnofrogs
April 09, 2015 04:32PM
I'm getting a weird error and I cant find the cause, I have also tried searching and havent found a solution.
Im using the current stable version (previous version) of arduino
A ramps board I believe 1.4
and I believe the newest version of marlin,
I'm receiving this error.
I switched over to Sprinter and its all working now, but whenever i print something it pops up with an error and cant finish past the first layer.
16:04:32.403 : N161 G91 *55
16:04:32.403 : N162 G1 Y0 F4800 *46
16:04:32.403 : N163 G90 *52
16:04:33.168 : N164 G91 *50
16:04:33.168 : N165 G1 Y0 F4800 *41
16:04:33.168 : N166 G90 *49
16:04:34.261 : N168 G91 *62
16:04:34.261 : N169 G1 Y50 F4800 *16
16:04:34.261 : N170 G90 *54
16:04:36.276 : N173 G91 *52
16:04:36.276 : N174 G1 Y-50 F4800 *49
16:04:36.276 : N175 G90 *51
16:04:39.699 : N179 G28 *60
16:04:39.699 : N180 M117 ETE 5m 44s *82
16:04:39.715 : N181 G1 Z0.2 F100 *1
16:04:39.715 : N182 M107 *14
16:04:39.715 : N183 G90 *58
16:04:39.715 : N184 M82 *52
16:04:39.715 : N185 M190 S20 *118
16:04:44.057 : N187 M104 T0 S210 *12
16:04:44.057 : N188 G92 E0 *102
16:04:44.057 : N189 M109 T0 S210 *15
16:04:44.057 : Serial Error: Line Number is not Last Line Number+1, Last Line:182
16:04:44.057 : Resend:183
16:04:44.073 : Resend: N183 G90 *58
16:04:44.073 : Resend: N184 M82 *52
16:04:44.073 : Resend: N185 M190 S20 *118
16:04:44.073 : Resend: N187 M104 T0 S210 *12
16:04:44.073 : Resend: N188 G92 E0 *102
16:04:44.073 : Resend: N189 M109 T0 S210 *15
16:04:44.073 : Serial Error: Line Number is not Last Line Number+1, Last Line:182
16:04:44.073 : Resend:183
16:04:44.089 : Serial Error: Line Number is not Last Line Number+1, Last Line:182
16:04:44.089 : Resend:183
16:04:44.089 : Resend: N183 G90 *58
16:04:44.089 : Resend: N184 M82 *52
16:04:44.089 : Resend: N185 M190 S20 *118
16:04:44.089 : Resend: N187 M104 T0 S210 *12
16:04:44.089 : Resend: N188 G92 E0 *102
16:04:44.089 : Resend: N189 M109 T0 S210 *15
16:04:44.104 : Error: checksum mismatch, Last Line:184
16:04:44.104 : Resend:185
16:04:44.104 : Resend: N183 G90 *58
16:04:44.104 : Resend: N184 M82 *52
16:04:44.104 : Resend: N185 M190 S20 *118
16:04:44.104 : Resend: N187 M104 T0 S210 *12
16:04:44.104 : Resend: N188 G92 E0 *102
16:04:44.104 : Resend: N189 M109 T0 S210 *15
16:04:44.120 : Serial Error: Line Number is not Last Line Number+1, Last Line:184
16:04:44.120 : Resend:185
16:04:44.120 : Error: No Checksum with line number, Last Line:186
16:04:44.120 : Resend: N185 M190 S20 *118
16:04:44.120 : Resend: N187 M104 T0 S210 *12
16:04:44.120 : Resend: N188 G92 E0 *102
16:04:44.120 : Resend: N189 M109 T0 S210 *15
16:04:44.120 : N190 M107 *13
16:04:44.120 : Resend:187
16:04:44.135 : Resend: N187 M104 T0 S210 *12
16:04:44.135 : Resend: N188 G92 E0 *102
16:04:44.135 : Resend: N189 M109 T0 S210 *15
16:04:44.135 : Resend: N190 M107 *13
16:04:44.135 : Serial Error: Line Number is not Last Line Number+1, Last Line:186
16:04:44.135 : Resend:187
16:04:44.135 : N191 G0 X125.492 Y149.279 Z0.296 F9000 *62
16:04:44.151 : Serial Error: Line Number is not Last Line Number+1, Last Line:186
16:04:44.151 : Resend:187
16:04:44.151 : Resend: N187 M104 T0 S210 *12
16:04:44.151 : Resend: N188 G92 E0 *102
16:04:44.151 : Resend: N189 M109 T0 S210 *15
16:04:44.151 : Resend: N190 M107 *13
16:04:44.151 : Resend: N191 G0 X125.492 Y149.279 Z0.296 F9000 *62
16:04:44.151 : Error: No Checksum with line number, Last Line:186
16:04:44.167 : Serial Error: Line Number is not Last Line Number+1, Last Line:186
16:04:44.167 : Resend:187
16:04:44.167 : Resend: N187 M104 T0 S210 *12
16:04:44.167 : Resend: N188 G92 E0 *102
16:04:44.167 : Resend: N189 M109 T0 S210 *15
16:04:44.167 : Resend: N190 M107 *13
16:04:44.167 : Resend: N191 G0 X125.492 Y149.279 Z0.296 F9000 *62
16:04:44.182 : Error: checksum mismatch, Last Line:187
16:04:44.182 : Resend:188
16:04:44.198 : Serial Error: Line Number is not Last Line Number+1, Last Line:187
16:04:44.198 : Resend:188
16:04:44.198 : Resend: N188 G92 E0 *102
16:04:44.198 : Resend: N189 M109 T0 S210 *15
16:04:44.198 : Resend: N190 M107 *13
16:04:44.198 : Resend: N191 G0 X125.492 Y149.279 Z0.296 F9000 *62
16:04:44.198 : Error: checksum mismatch, Last Line:187
16:04:44.213 : Serial Error: Line Number is not Last Line Number+1, Last Line:187
16:04:44.213 : Resend:188
16:04:44.229 : Resend: N188 G92 E0 *102
16:04:44.229 : Resend: N189 M109 T0 S210 *15
16:04:44.229 : Resend: N190 M107 *13
16:04:44.229 : Resend: N191 G0 X125.492 Y149.279 Z0.296 F9000 *62
Edited 1 time(s). Last edit at 04/09/2015 07:26PM by Hypnofrogs.
Re: Marlin Upload problem
April 10, 2015 07:06AM
DEFAULT_TRAVEL_ACCELERATION should be in the configuration.h close to the other speed defines. If you use an example_config you should also compare them with the original files because there are not always up to date.
April 11, 2015 02:39AM
thanks a lot! got it all working! Printing off a cable chain I designed right now!
