duet + reprap firmware - macros on sd card can't be read January 14, 2016 06:31AM |
Re: duet + reprap firmware - macros on sd card can't be read January 14, 2016 10:39AM |
Janosch2015
Firmware: RepRapFirmware-dev_1.09m-dc42
Board: Duet 0.8.5 + Duex 0.2a
Software: Repetier-Host V1.6.0
Hello,
I created my own macro and saved it in the sys folder on the SD-card.
Name of the macro: test1.g
Content of test1.g:
M18 E0 E1 E2 E3 E4 E5 ;disable all extruder motors
When I am trying to execute the macro by sending M98 Ptest1.g to the board, I receive the message " Can't open 0:/sys/0 to read, error code 4
Macro file 0 not found" and nothing happens.
Its the same when I try to execute one of the already exisiting macros like homedelta.g.
Is it not possible to use the M98 command like this?
kind regards!
Re: duet + reprap firmware - macros on sd card can't be read January 14, 2016 11:08AM |
Re: duet + reprap firmware - macros on sd card can't be read January 14, 2016 11:14AM |
Janosch2015
Hey Doug,
if I put test1.g in the folder macros and send M98 Ptest1.g it doesn't work either. I also tried without ".g" (only M98 Ptest1) like the other example files in the folder... didn't work. Are you able to run macros like this?
Re: duet + reprap firmware - macros on sd card can't be read January 15, 2016 07:45PM |
Janosch2015
Hello,
Content of test1.g:
kind regards!
Re: duet + reprap firmware - macros on sd card can't be read January 18, 2016 06:11AM |
