[RRF] Extruder max speed vs. retraction setup November 26, 2016 01:51PM |
Re: [RRF] Extruder max speed vs. retraction setup November 26, 2016 03:40PM |
Re: [RRF] Extruder max speed vs. retraction setup November 29, 2016 07:11AM |
Re: [RRF] Extruder max speed vs. retraction setup November 29, 2016 04:03PM |
o_lampe
There's another thing I've noticed related to hardware retraction:
I'm often using only 2 of 3 filaments with my diamond hotend. The mixing ratio clearly shows which filament isn't used. But still it is retracted/unretracted over and over again, until the drive gear has chewed through it. ( almost )
The parameter that only allows retraction after XXmm of extrusion should relate to the mixing ratio and treat each extruder separately.
The unused extruder doesn't apply pressure to the melting chamber, so there is no need to retract it anyways.
Apologies, if this has long been done, I'm still running RRF V1.14 on a RADDS.
Re: [RRF] Extruder max speed vs. retraction setup November 30, 2016 05:27AM |
... G1 X-0.893 Y3.332 E1.26709 G1 X-0.893 Y21.465 E0.65279 G10 ; retract T3 G10 ; retract G1 X8.035 Y16.198 F4800.000 G11 ; unretract G1 X1.094 Y9.256 E0.35494 F1800.000 G1 X1.094 Y9.748 E0.01779 ...
Re: [RRF] Extruder max speed vs. retraction setup November 30, 2016 06:48AM |
Re: [RRF] Extruder max speed vs. retraction setup November 30, 2016 08:01AM |
Re: [RRF] Extruder max speed vs. retraction setup November 30, 2016 03:46PM |
