Discussion of new M600 Change Filament command in Marlin firmware January 27, 2013 07:13PM |
Added a feature to have filament change by gcode or display trigger.
[default off for now]
syntax: M600 X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal]
if enabled, after a M600, the printer will retract by E, lift by Z, move to XY, retract even more filament.
Oh, and it will display "remove filament" and beep like crazy.
You are then supposed to insert a new filament (other color, e.g.) and click the display to continue.
After having the nozzle cleaned manually, aided by the disabled e-steppers.
After clicking, the printer will then go back the whole shebang, and continue printing with a fancy new color.
Re: Discussion of new M600 Change Filament command in Marlin firmware January 27, 2013 07:15PM |
Re: Discussion of new M600 Change Filament command in Marlin firmware January 27, 2013 07:17PM |
Re: Discussion of new M600 Change Filament command in Marlin firmware January 27, 2013 09:04PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Discussion of new M600 Change Filament command in Marlin firmware January 28, 2013 02:52AM |
Re: Discussion of new M600 Change Filament command in Marlin firmware January 28, 2013 03:00AM |
Re: Discussion of new M600 Change Filament command in Marlin firmware January 28, 2013 06:21AM |
Re: Discussion of new M600 Change Filament command in Marlin firmware January 29, 2013 01:28AM |
Re: Discussion of new M600 Change Filament command in Marlin firmware January 30, 2013 07:13PM |
Re: Discussion of new M600 Change Filament command in Marlin firmware February 01, 2013 02:36AM |
Re: Discussion of new M600 Change Filament command in Marlin firmware February 02, 2013 09:55AM |
Re: Discussion of new M600 Change Filament command in Marlin firmware May 25, 2016 12:26PM |
Re: Discussion of new M600 Change Filament command in Marlin firmware May 31, 2016 11:18PM |
